Technical e brake question
Discussion in 'The Hokey Ass Message Board' started by Tim, Apr 23, 2019.
  1. Tim
    Tim
    from KCMO
    Hey guys,
    Looking to put an ebrake back into my 46 ford.
    Looking at the options available I’m not seeing a real clear reason I couldn’t use the stock ford set up but attached to the brakes on the 9 inch ford instead of the banjo.
    The only modification that stares me in the face is originally a tab was located on the torque tube towards the front of the car to locate and hold the end of the forward cable.
    But it seems a small 90 deg tab/bracket off the X member should be able to accomplish that pretty easy.
    I just figured I’d ask before I order parts in case I’m missing something
  2. Your headed the right direction. I have used the O.E. stuff with small mod's on nearly every rear end change I've done and I've changed over many rear axles.
  3. Tim
    Tim
    from KCMO
    Cool. I’m kinda curious what I should do about the point the cable exits the backing plate.
    Stock 9” has a sheathed cable and I think stock 46 has a little boot that cover the cable end.
    Any thoughts on that? I can see a few ways around it either way just wanting some feed back/ ideas as I’ve never done this bit before.
    Thanks
  4. gene-koning
    gene-koning
    I don't know how the cables are set up on your original car, but..
    I use the brake cables designed for what ever rear axle I'm using. Then I connect an intermediate cable to both side cables from the rear brakes using what ever cable attachment parts the modern cables use. I make a "T" to connect to the front cable going to the e brake handle and hook it to the intermediate cable. Depending on how the front cable is routed, you may have to fabricate a steel loop to hold the passenger side of the intermediate cable up to the frame or trans crossmember.
    Tim likes this.
