E Z Tech \Shift Knob
Discussion in 'The Hokey Ass Message Board' started by G V Gordon, Aug 4, 2004.
  1. G V Gordon
    G V Gordon
    from Enid OK
    Guess this qualifies for Tech Week.
    Quick and easy and applicable to ALMOST any item you would want to put on the end of your stick. [​IMG]
    First the materials:
    The item is in this case a cue ball I picked up for 99 cents at a local discount house, a threaded conector that fits my old pickup shifter, and a good two part epoxy.
  2. G V Gordon
    G V Gordon
    from Enid OK
    Second drill a hole that is a snug fit for the connector, The gaps resulting from a hex item in a round hole allow for epoxy to fill the voids on the sides for better bonding.
  3. G V Gordon
    G V Gordon
    from Enid OK
    Drill the hole about half the length of the connector.
  4. G V Gordon
    G V Gordon
    from Enid OK
    mix the epoxy as directed
  5. G V Gordon
    G V Gordon
    from Enid OK
    coat the hole and the connector and tap into place firmly. Then work epoxy into the voids along the sides.
  6. G V Gordon
    G V Gordon
    from Enid OK
    And "Viola" the finished product mounted in Ol' Yeller.
    I was going to make an eyball out of it but I'm kind of diggin' the cl***ic look.
    Thanks for your attention and, "Do try this at home". [​IMG]
  7. G V Gordon
    G V Gordon
    from Enid OK
    bttt, since it's still tech week.
  8. Django
    Django
    from Chicago
    This will come in handy for me very soon. Thanks!
    Can you get that connector at any hardware store?
  9. Jester
    Jester
    from Blevins AR
    Far out George....one problem though........no lines on it....whats wrong man I thought for sure you'd pull a line or two or ten on it [​IMG]
  10. luketrash
    luketrash
    Potentially (depending on how much you care) you can stick some clear mailing tape over the spot where you're going to drill to help prevent the chipping off of plastic around the mounting hole.
  11. HotRodHon
    HotRodHon
    Not to be too much of a smart ***, but I just drill and tap the Billiard balls. [​IMG]
    The plastic they use for billiard balls is hard as nails, and taps beautifully.
    I've done at least ten or so this way. Have'nt broken one yet.
    Just my $.002 [​IMG]
  12. G V Gordon
    G V Gordon
    from Enid OK
    Jester: I bought three of the cue balls so I plan on doing two more. They will be a bit more colorfull.
    39Sled. One of the reasons I used an insert was that on the old truck 4 speed it has a jam nut and that gave me a hex nut to hold onto while I tightened the jam nut. Each case is different for sure. It also gave me about an inch extention and I like where it set the knob better for my 5 year old grandson to reach,(he likes to shift PaPa's truck. [​IMG]
  13. G V Gordon
    G V Gordon
    from Enid OK
    Django, yea, any good hardware store carries an ***ortment of them.
    LukeTrash, good tip, I'll try that on the next one.
  14. Old Yellar just keeps gettin cooler!! [​IMG]
  15. Hey that looks almost like my old lucky shift knob, minus the nearly 50 years worth of checks cracks and palm crust.
    Very cool.
  16. middleskewl
    middleskewl
    here's mine.
  17. Thirtycoup
    Thirtycoup
    cool post man, simple, looks good and even a dumb*** like me can't screw it up too bad! question, what did you hold the ball with while drilling it, just your hand? mike
  18. G V Gordon
    G V Gordon
    from Enid OK
    Yea, they are not hard to drill. My drill press table has a small hole that it sat in to keep i square. If you needed to, you could use a small spray paint lid or something like that to set it in.
  19. slowpoke
    slowpoke
    from Austin, TX
    Very cool simple tech. Tape suggestion aside...Did you use any kind of special masonary bit to perform better (less cracking, chipping, etc.)...or will any style bit work? Thanks.
  20. middleskewl
    middleskewl
    had mine clamped between 2 V blocks. Broke the first ball
    because it seemed to be cutting really easy but in a blink
    it started smoking and cracked the ball. i used a regular
    high speed steel bit for the threaded hole and a carbide
    end mill for the counterbore for the ****on. slow speed,
    (1000 RPM) slow feed. Also broke one with a tap. Tap hole was too small. some oil on the tap helped out a bunch too.
  21. zman
    zman
    from Garner, NC
    bttt for tech week
