EAB cam
Discussion in 'The Hokey Ass Message Board' started by flashback, Sep 14, 2009.
  1. flashback
    flashback
    Anyone know anything about a EAB-6252 ford cam?
    John
  2. T-Time
    T-Time
    from USA
    1952 Ford V8 camshaft. Will fit 1949-53 flatheads.
    .328 int, .328 exh.
    I'm not sure if the "late stock" cam shown in the photo is the EAB cam, or not.
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Late Merc cams are slightly better still - probably can't tell much of a difference in seat of the pants though.
  4. flashback
    flashback
    Thanks for the help.
    John
  5. quickgene
    quickgene
    from duluth mn
    I heard that any 52 or 53 ford or merc cam with EA the first 2 letters is the best lift cam. Not sure on 52 maybe only the 1953 engine has the best cam. Gene
  6. Bruce Lancaster
    Bruce Lancaster
    '52-3 same. Ford released 2 sets of specs, discussed in HRM...inclusion of ramps made it look hotter than it was, but it was significantly hotter than the very tame '37-51 cams. I don't know how it compares with the '32-6, which were hooter than '40's ones. One set of specs is in the shop manual or '53 supplement, but I don't know if the information can be squared with modern sustems. Flatdog fully measured one using modern 050 lift standard. I'll see if I can find the numbers he gave me. If you search, I poste torque curve for late Merc on here somewhere.
