Technical EAB HEADS
Discussion in 'Traditional Hot Rods' started by robert graves, Sep 21, 2020.
  1. robert graves
    robert graves
    What compression ratio will I get using EAB heads with a 4” Merc crank ? In an 8ba flathead ford v8
  2. slowspoke
    slowspoke
    You need to look at the Flathead Compression Ratio Charts by James K. Leis. It’s a pretty extensive comparison that should address your question.
    RMR&C likes this.
  3. patterg2003
    patterg2003
    This is the Flathead Compression Ratio Charts by James K. Leis.
