Hot Rods Early 265 and 283 solid lifter cam spec's.
Discussion in 'The Hokey Ass Message Board' started by pdq67, Jul 12, 2015.
  1. pdq67
    pdq67
    I read where Chevy made several little solid lifter cams for the way early short-stroke engines so am wondering what their part numbers are as well as lift and timing spec's. -097 Little Duntov and earlier here.
    Just for reference is all.
    Thanks,
    pdq67
  2. sunbeam
    sunbeam
    097 228 intake and 230 ex @ .50 .394 and 400 lift.
  3. pdq67
    pdq67
    Thanks sunbeam, who know's the rest of them?
    pdq67
  4. Larry T
    Larry T
    You can probably find them in an old Crane catalog under Blueprint Cams for stock cl***es.
  5. chase knight
    chase knight
    There was also the 3836700 in the 1955 265's. Duration at .050" is 174 intake, 177 exhaust. Lobe separation is 108 degrees. Gross valve lift is .346" intake, .354" exhaust. Valve lash hot is .008" intake, .016" exhaust. Regards, Chase
