Technical Early 28 model a oil pan
Discussion in 'Traditional Hot Rods' started by Tedders, Apr 24, 2016.
  1. Tedders
    Tedders
    Just want to double check when I change the oil I loosen the big middle bolt correct?
  2. Hitchhiker
    Hitchhiker
    correct
    Tedders likes this.
  3. Tedders
    Tedders
    Thank you
  4. Tedders
    Tedders
    Just found a new issue
  5. mike bowling
    mike bowling
    That's a good oil pan to have- you can service the oil pump screen without dropping the whole pan .
    Model A's are like Harleys, they always leak! A guy told me they mark their territory that way.
  6. Texas Webb
    Texas Webb
    Yep,had 2 Harleys.
  7. seb fontana
    seb fontana
    from ct
    Add Crosley...
  8. Tedders
    Tedders
    What's Crosley?
  9. 270ci
    270ci
    That's not a new issue. Oil leaks have been around as long as engines have.
  10. Tedders
    Tedders
    Drips yes but this maybe more as I have driven very little. Changing it tomorrow will be able to see better after what's what
  11. Bader2
    Bader2
    If your fords not leaking,check the oil it's probly empty!
    mike bowling likes this.
  12. Barn Find
    Barn Find
    from Missouri
    Model A does not have a rear main seal. They just have a slinger. If you drive or park on a steep incline, oil will run out the back. AA trucks had a check ball, so oil would not run into the grain hopper back when they would dump the grain by tipping up the whole truck at the grain elevator.
  13. Barn Find
    Barn Find
    from Missouri
    Dad put a seal in his '31 pickup, and has not been happy with it. To install the seal,. you have to machine the slinger off the crank. Other than that, his truck runs great. So, he installed a can under the motor to catch the oil. The can has a pet**** on it, that he drains.
    And this is what a Crosly looks like.
  14. alchemy
    alchemy
    A radio. And everybody knows radios don't leak oil.
    Barn Find likes this.
