I'm working on a ZU-4 Bosch mag that has an issue- the Bakelite commutator bearing on the armature is cracked. I do have an incomplete ZR-4 with a good bearing, but the gears are different sizes. If you look carefully at the (lousy) pics, it looks like the gears have a lock ring that can be unscrewed, but I don't want to break anything! Here are my questions for you gurus: Can the gears be removed and swapped? Can the commutators be pressed off and switched? I do have the broken part from the commutator bearing- can it be glued/reinforced from the back and used safely? Many thanks! Bill
Here are some useful information, https://occhiolungo.wordpress.com/2012/02/02/how-to-more-magneto-rebuild-tips/
