Hot Rods Early Chevy Distributor
Discussion in 'The Hokey Ass Message Board' started by krylon32, Apr 22, 2024.
  1. ClayMart
    ClayMart
    I suspect that a lot of the issues with electronic ignition conversions are due to less than ideal installations. In general they tend to work best with a "cleaner" current supply. I wouldn't worry so much about using them on a vehicle with an alternator and a solid state voltage regulator. And carefully following the manufacturer's installation instructions.
    For an older car or truck with a generator and a mechanical regulator I'd lean more towards the points and condenser set up. They seem to be more tolerant of having a slightly "dirtier" current output from the charging system.
    firstinsteele likes this.
  2. krylon32
    krylon32
    from Nebraska
    My truck has an Igniter II Module with a Bosch BC 12 coil.
  3. Roothawg
    Roothawg
    I think it's the roll of the dice honestly. New parts, regardless of the mfg. these days are a 50/50 shot of failure. I agree with Mark, if you want to convert back to points, it isn't that hard to do, but use NOS parts. I had good luck with my Pertronix, but I have heard horror stories, so use your best judgement.
  4. hepme
    hepme
    yeah, just go to the msd site and check one out. Leave off top cap. [​IMG]
    Budget36 likes this.
  5. krylon32
    krylon32
    from Nebraska
    Talked to the builder. He switched back to an igniter I from a II because of reliability? He also switched to a Bosch internal resistor 3.3 ohm coil for reliability. I'm building a spare distributor to keep in the tool box and thought about a spare coil but am finding the Bosch coil hard to find. I'm curious how a product (Pertronix) which seems to have a sketchy history of reliability is so popular? The shop I have used for the past 20 years building cars just scoffs when I mention points. My best experience with electronic ignition was back when I was using the Chevy ZZZ, ZZ3 & 4 Chevy crate motors with the factory HEI. I can't remember a failure and I drove them lots of miles. They are a little large but seem to work good.
  6. krylon32
    krylon32
    from Nebraska
    The man I traded the pickup out of said he was smokin the Pertronix modules until a friend told him to go to a Bosch #00-12 coil and that seemed to solve the problem. My local parts store has the coil on order.
  7. 51504bat
    51504bat
    Pertronix don't like solid wires.
