History Early Chrysler Speed Control?
Discussion in 'The Hokey Ass Message Board' started by gatz, Jul 4, 2023.
  1. gatz
    gatz
    Is this an early Chrysler Speed Control?
    Can't recall just where I found this pic.
    Mods, if it ends up that it is from a post-65 vehicle, go ahead and delete.
    Didn't Buick have one of the 1st speed controls in '62?
    In_The_Pink and egads like this.
  2. Los_Control
    Los_Control
    from TX
    Looks modern to me .... the early speed control was the flathead 6
    egads, Just Gary and 1952henry like this.
  3. partsdawg
    partsdawg
    from Minnesota
    Yes. It was called Auto Pilot. Dash looks to be a 1958 Saratoga.
  4. In_The_Pink
    In_The_Pink
    egads, SS327 and rusty valley like this.
  5. gatz
    gatz
    Found a bunch of Chrysler's "Auto Pilot" on the 'net.
    Seems most are dash mounted, not not on the column
    Would be neat to find one and adapt it like @In_The_Pink is hinting at
  6. stuart in mn
    stuart in mn
  7. v8flat44
    v8flat44
    My 50 Ford 6 cyl. had a hand throttle. Pull a handle out and it would stay at that speed on flat land.
    By the way los_control, that flathead 6 outran some V8s ....... :D
  8. gatz
    gatz
    that's it, stuart
    @v8flat44
    when I was only about 5 yrs old, my Dad would be out combining oats. He had me sit in the old REO pickup with the engine running, he'd put it low gear and pull the hand throttle about half way out, then jump off the running board and got on the AC tractor to continue combining.
    Of course my feet couldn't reach the clutch or brake pedals and therefore couldn't use the gear-shift, which at the time was a big mystery with all those numbers and lines.
    My job was to watch for him to wave when the bin got full and drive over near to where he was so that he could drive the REO under the unloading spout.
    All the time sorta "driving" it in a circle around the field; ~ 40 acres.
    Biggest worry was running over Dad, but that never happened.
    sidevalve8ba likes this.
  9. sidevalve8ba
    sidevalve8ba
    When I was a teen-ager my father had a '64 Chrysler that had Auto Pilot. If I remember correctly the unit was vacuum operated.
  10. In_The_Pink
    In_The_Pink
    I will definitely be looking into it more, especially the dash mounted version, as I really don't have a traditional steering column to work with. Not sure if the backpressure throttle pedal thing is necessary or not, but I think it could be adapted to non-Chryslers without too much work. I suspect finding the knob and switch in good nick will be the most challenging part.
    302GMC likes this.
