Technical Early Flathead Pistons for 4" stroke?
Discussion in 'Traditional Hot Rods' started by dmar836, Oct 3, 2023.
  1. dmar836
    dmar836
    My '40 block is original bore but measured about .020 out at the worst place. I have a good Ford crank but two good 4" Mercs so would like to use one of those with 8BA rods. I have some .030 pistons but those are 3.1875 rather than the 3.0625.I do not want to just to a 3.1875 bore though that would be super cheap to do. I'll be doing the bores myself and would rather not sonic test just to jump many bore sizes.
    I am not finding a source for the early pistons(O/S or not) for the 4" stroke.
    Is this a special order only?
    Also, isn't it true that I can insert the piston/rods from below since the 8BA big ends won't fit the smaller bore?
    Thanks in advance,
    D
  2. tubman
    tubman
    That's one of the advantages of a 3 3/16" bore. I'm really only familiar with 8BA's, but I have never had a problem going 1/8" over. I would think the 221's would be even better, given they are 24 studs. The 21 stud blocks, I don't know.
  3. rusty valley
    rusty valley
    You need merc pistons. I would check with Mac VP, or Egge
    seb fontana likes this.
  4. dmar836
    dmar836
    I checked those sites but 3.1875 is the standard. I suppose the obvious issue is the small early bore which was never mixed from the factory with the later 4” crank.
    I guess that means custom to me. D
