Technical Early Ford 3 speed compatibility?
Discussion in 'The Hokey Ass Message Board' started by Aaron D., May 13, 2021.
  1. Aaron D.
    Aaron D.
    I have two early Ford 3 speeds, one is a “78” case truck open drive top shifter. The other is a 3 speed side shifter out of a 51 Ford Coupe. Both have the late syncros. Can I take the car 1st, 2nd, reverse, and cluster gear out of the side shift and directly install them into the top shifter case so I have an open drive top shifter with higher car gears?
    @vanpelt
    @ Mac VP
  2. Model A Gomez
    Model A Gomez
    Was going to suggest Vanpelt Sales but they are already on there, They have a parts list which might help with interchange information.
  3. Budget36
    Budget36
    Looks like you put a space in your “page”
    @Mac VP
    Aaron D. likes this.
  4. 1pickup
    1pickup
    Mac is the expert. But, I'm pretty sure that won't work. You CAN use the gears out of a side shift trans from '40-'48 (I did!). The '49-up is a different trans.
    stillrunners likes this.
  5. Mac VP
    Mac VP
    You really must know which gears are in the open drive transmission before anyone can determine if the 51 car transmission gears are interchangeable. There are 3 basic gear sets used by Ford in the open drive 3 speed light duty transmissions:
    1) 1942-44 transmission - the 78 case with either the 28 or 29 tooth cluster gear
    2) 1945-50 transmission - the 78 case with either the 28 or 29 tooth cluster gear
    3) 1950-51 transmission - the 78 case with the 27 tooth cluster gear
    Nothing in the 1942-50 open drive transmissions can be swapped with the 51 p***enger car 3 speed except the synchro ***embly. In fact, only a few gears or shafts from a 51 car transmission can be used in the 51-52 open drive pickup truck transmissions.
