Technical Early Ford Front Axle Hub Conversion Question
Discussion in 'Traditional Hot Rods' started by Delray, Mar 4, 2016.
  1. Delray
    Delray
    I have a ton and a half '35 Ford front axle with Budd style hubs and mechanical brakes. Is there a feasible way to convert to a juice brake hub that accepts a model A pattern wire wheel??
  2. You may have to switch to a car spindle, but yes it can be converted using Lincoln backing plates, hubs and drums.
    Search Lincoln brakes or Juice brake conversion or the like.
  3. Delray
    Delray
    So car and light truck spindles will fit on the king pins of the truck axle?
  4. alchemy
    alchemy
    Don't think so. IIRC the truck size kingpin is larger than a car's.
  5. Texas Webb
    Texas Webb
    Might ask over on Ford Barn.Lots of smart folks over there.
  6. I would disagree with you but I am thinking that you are probably correct. May this is an @Bruce Lancaster question. he knows all that chit. ;)
  7. RICH B
    RICH B
    I have a set of early big truck spindles; while they use a larger kingpin, the snout is the same as p***enger car. I do not know the exact year of the spindles tho, they are flat sided like '32-'36 car and the arms are shaped kinda like '35-'36 arms. If your 1-1/2 ton spindles were the same it would be easy to switch to '40 up juice brakes and drums that will fit an "A" wheel with a support ring. Only thing those big truck axles are "BIG".
  8. LOL he could tell everyone that it is a '32 extra heavy. ;)
  9. Delray
    Delray
    I was thinking they were bigger. It's under snow right now but I'm getting antsy waiting on spring. Back in the 60's I machined and bushed '37 car spindles to fit Chevy hubs. I just like to go the easiest way. Thank you all for your help.
  10. Delray
    Delray
    If my old '37 car hubs fit these truck spindles will the '40 up also fit?
  11. RICH B
    RICH B
    Sure.
    Here is a picture of the truck spindles I have along with one (top) matched up to a '37-'41 car spindle (bottom).
  12. Corn Fed
    Corn Fed
    I don't think the pics RICH B is showing are big truck. I bet they are from a Pickup. The spindles on a 32-34 big truck have 6 holes that hold the backing plate on instead of the p***enger car 4 and I believe they are a bigger diameter at the mounting flange. So at least on those years it's not a direct bolt on. I'd think your best bet would be to try and make the axle fit p***enger car spindles by making sleeves for the king pins.
  13. Delray
    Delray
    It's supposed to warm up in the next couple weeks. I'll get a hub pulled and see what I have to deal with. The king pin sleeve would be a lot easier than machining a spindle if it came down to that. Thanks again for all the info.
  14. Internet
    Internet
    I wont try and quote kingpin dimensions from memory, but is it not possible that the ton and a half is the same o.d. as an f100 if it is bigger than say 28-41 car size?
    if it was, a set of f100 brakes and hubs would theoretically bolt on, but I believe the KPI is 2 degrees or so different from early ford to f100.
  15. Delray
    Delray
    It's possible the KPI on the car is different than the same year 1 1/2 ton truck. Mix and match can bite you.
  16. RICH B
    RICH B
    Definitely not pick-up; which are the same as car spindles. Like I said not sure of the year; but the kingpin is larger than the normal 13/16" and the axle yoke is quite a bit larger than a car axle, these are "bearing on top" spindles so what ever axle they were on had a lot larger profile than a car or 1/2 ton pick-up.
    The bolt pattern and register seem to match pre-'37 car and pick-up when measured and compared against a juice brake backing plate. They are also cross steer which should be post '34, I think.
    I have seen the six bolt pattern spindles somewhere too. I'm thinking on Model A big trucks which could very well have carried over into the '32-'34 trucks.
    All in all, a couple pieces of useless mystery parts to keep in a corner in case I ever figure out a use for them.
  17. Delray
    Delray
    Thanks for posting the pics. I dug mine out and it has the 6 bolt backing plates and it is huge compared to a bare '37 car axle I have. Now I'm curious as to what will fit on the spindles. If I come up with some useful info I will post.
  18. Corn Fed
    Corn Fed
    If you have a friend with a lathe, maybe you could weld up the 6 holes, then turn the whole outer part of the spindle down to match a p***enger car. Redrill the 4 holes. Of course you'll need to check that the kingpins won't interfere with the backing plate.
