Needed to make an adapter for the Sending Unit on my 1947 Ford Truck. As I understand Ford used that pattern for a LONG time. I looked all over the web and couldn't find it so I ended up reverse engineering it. If you ever need to do the same this might save you some time - see pics. Or you can use the piece of paper and a dirty hand to make a pattern - I've had sucess using BOTH methods!!!
