Technical Early ford tapered steering shaft?
Discussion in 'The Hokey Ass Message Board' started by AV8R, Dec 26, 2023.
  1. AV8R
    AV8R
    Does anyone know where you can buy a tapered steering shaft? I have a 1932 column I'm using with a Vega box and a 1937 steering wheel. Thanks!
  2. krylon32
    krylon32
    from Nebraska
    I think I still have a few left from when I was manufacturing steering columns. Mine are 33 inches long with the keyed and tapered top which duplicates the Ford top and 3/4 36 spline bottom. Used them in both my 39 banjo column and my 40 column. The length was just right for the model A thru 34 cars.
    Nailhead Jason likes this.
  3. hotrodA
    hotrodA
    I bought a replacement shaft from Weedeter.
    He has three different lengths, tapered on the top and 3/4” DD on the bottom.
    Dale is @Weedburner 40 in here.
  4. Weedburner 40
    Weedburner 40
    We can also make custom length shafts.
    Nailhead Jason and Bob Lowry like this.
  5. 31Apickup
    31Apickup
    Are they solid shafts or hollow?
    Johnny Gee likes this.
  6. krylon32
    krylon32
    from Nebraska
    Mine are solid.
  7. 38 Hump
    38 Hump
    If not the whole shaft how about a male / female 3/4 36 spline taper x 3/4" coupler (female) stub shaft to enable a steering wheel swap? Clear??!!
  8. Weedburner 40
    Weedburner 40
    They are hollow just like originals.
    31Apickup likes this.
  9. 38 Hump
    38 Hump
    To clarify my above post: The adapter shaft would only about 4 - 6" long (if that helps). If I am hijacking this thread please omit.
  10. krylon32
    krylon32
    from Nebraska
    Just forget about mine.
