Technical Early ford tie rod ends for split wishbone?
Discussion in 'Traditional Hot Rods' started by dumprat, Jan 26, 2015.
  1. dumprat
    dumprat
    from b.c.
    I see some early style cars running the old ball and socket tie rod ends for the pivot on the split bones. For those running this set up is there anything I should be looking out for? Problems? pitfalls? Considerations.?
    Thanks.
  2. big duece
    big duece
    from kansas
    I plan on using the 32-34 style with some so-cal hangers. There might be others that are better, but I like the vintage style of these. 2014-12-23 23.09.13.jpg 2014-12-23 23.08.52.jpg
    kidcampbell71 and nailhead29A like this.
  3. The37Kid
    The37Kid
    When you are shopping for these they come with the grease fitting on either the top or bottom. I like the ones in the above photo, they are safer in my mind, you won't wack a finger washing off the ch***is. Bob
  4. RICH B
    RICH B
    I always liked how Fred Rowe welded his directly into the bones on his '28 modified (no adjustment); looked really smooth. The current crop with the ends screwed onto threaded bungs look kinda "stretched out" to me.
    bct likes this.
  5. rusty rocket
    rusty rocket
    Hmmmm I must be living under a rock I've never seen those used.
  6. bct
    bct
    the chevy ones I used have holes for a cotter pin to slide down the end cap slot and lock it in place.
  7. Texas Webb
    Texas Webb
    ^^^Ford has the same.
  8. dumprat
    dumprat
    from b.c.
    Mine are 32's. Not sure where the fitting is? Dosent matter much.
    Do they bind?
  9. oj
    oj
    A member on here is a machinest and has some of those adapters for sale, I made my own before they were available and they are a pita to make. The other consideration is getting just the right length.
  10. dumprat
    dumprat
    from b.c.
    I can make my own adapters. That is easy for me. I am more concerned on their function.
  11. timwhit
    timwhit
    Rusty: This is a trick we learned from our fore fathers. I've seen them in very old magazines. Tim btw: I'm coming up there @ May 29th.
  12. timwhit
    timwhit
    Rusty: I've sen these in some very old hot rod type magazines so they've been used for quite a while. btw: I'm coming up there @May 29th. Tim
  13. alchemy
    alchemy
    I think they look goofy if a guy isn't using the same kind of ends on the tie rod.
    nickk and RICH B like this.
  14. krylon32
    krylon32
    from Nebraska
    Soon I'm doing a more vintage style ch***is and using early ends on the radius rods and tie rod and drag link. I agree everything needs to tie together. In the past I've had Richard at I think it's called the V8 garage make my tie rod and drag link shafts. Only thing is, I've tried to find original studs as some say the repros are soft and don't have quite the right taper?
  15. dumprat
    dumprat
    from b.c.
    I am running 32-34 spindles with the same style tie rod ends.
  16. nickk
    nickk
    I've HEARD, but no experience, to use good originals because their so much stronger, and I have seen in restoration magazines that have them for sell to use originals if available.
  17. HOTRODPRIMER
    HOTRODPRIMER
    I used them om my pickup and have never had any problems. HRP
  18. From what I remember back in the day, those were kind of the standard for most backyard builders.
  19. RICH B
    RICH B
    Around here, before the introduction of those modern street rod threaded bungs, we cut the threaded ends off a '35 up Ford tie rod and welded them into the split ends of the wishbone.
  20. Paul
    Paul
    Editor
    I'd be concerned with the possibility of bump steer with the ball and cup held in place with a spring.. no?
  21. Pewsplace
    Pewsplace
    Hot Rod Primer shows tie rods used in the bones which are very safe. The ball and socket as shown in the lead photo is the same principle but doesn't provide the same movement as the later tie rod does. They both work and reproductions are available that screw directly in to the end of the bone. The Early Ford Store of California had some in stock the other day when I visited them. I am not sure who made them but I want to say Haze is the company. I believe usage is all about the looks rather than safety.
  22. Pewsplace
    Pewsplace
    The company is Haze City Specialties in Corona CA. Here is a photo of their set up. They have a website.
  23. snopeks garage
    snopeks garage
    from macomb MI
  24. Paul
    Paul
    Editor
    I started in that direction on one of my projects but changed my mind and went with the more conventional route
    early construction photo:
  25. dumprat
    dumprat
    from b.c.
    Ugg! When did all become buy this, buy that?
    Please explain why this would induce bump steer?
    Nobody has yet to answer my question.
  26. big duece
    big duece
    from kansas
    I have been hesitant to weld them, also thinking they might be too long. Is there a magical spot under the frame where they should mount? Always understood the longer the better. 2" shorter would put the frame bracket right at the feature line on the frame.
  27. big duece
    big duece
    from kansas
    I do not have any ON road experience with them, I cant help with OP's questions.
  28. RICH B
    RICH B
    I don't think there would be enough deflection to effect directional stability. Even tho there is a spring inside, I have never really seen any "play" or "motion" in these style ends in my experience with similar ends on the steering gear of heavy equipment. I always felt the spring tension compensated for wear on the ball and discs, between adjustments.
  29. Jethro
    Jethro
    Big Deuce.....do you have any pics of the frame mounts for the radius rods?....Those look trick1
  30. big duece
    big duece
    from kansas
    w.est1946.com/ch***ismountingtabs.aspx
    Item "A" , it looks plain in the pic but mine came in with the stamped detail like a forging.
