Technical Early ford trans parts
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Jan 7, 2025.
  1. wheeltramp brian
    wheeltramp brian
    Friend gave me a bucket of early ford trans parts.said it had some zephyr gears so I was interested. No zephyr gears and all surface rusted.worth anything? I'm thinking 5 bucks just so I can make a clutch alignment tool out of an input shaft. 20250107_162513.jpg 20250107_162517.jpg
  2. FritzJr
    FritzJr
    The open drive tailshaft housing is worth something.
  3. alchemy
    alchemy
    Would be worth a soak in Evaporust to see if the gears or syncros clean up ok. The snout and open drive rear cover could be blasted. Heck I’d probably give any of them a light blasting, making sure to protect bushings and polished surfaces. If the teeth end up being unchewed I’d probably use them.
    jet996, winduptoy and Automotive Stud like this.
  4. rusty valley
    rusty valley
    Main thing is the bearing surface inside the input shaft, and counter shaft, then the surface of the front bearing pilot of the main shaft
  5. wheeltramp brian
    wheeltramp brian
    I'll look them over a little closer today.
  6. banjorear
    banjorear
    Those second gears are worth decent money if they can be cleaned, bushing is still good and no pitting on the teeth.
  7. tubman
    tubman
    I have heard that Charlie Schwendler in New York is one of the few people who can successfully rebush Ford second gears.
    winduptoy likes this.
  8. I would definitely try to clean them up then inspect for pitting, etc.
