Technical Early GM ignitions
Discussion in 'The Hokey Ass Message Board' started by Voh, Sep 1, 2015.
  1. Voh
    Voh
    I have a '41 that has the original ignition key set. My understanding is that this is just an on/off switch because of the foot starter pedal.
    What year did GM start having a off-on-start ignition?
    Thanks
  2. Mr48chev
    Hell if you are doing an engine swap just stick a push ****on starter ****on under the dash and call it good.
  3. squirrel
    Trucks with the Six engine didn't get a key start till 1960 (!) they still had the food pedal in 59 on standard shift Six cylinders.
  4. squirrel
  5. Voh
    Voh
    I had thought about the ****on. But the stock ignition has the flexible "conduit" and the end modified.
    Would the 49-52 cars have a start position?
  6. squirrel
    1949 was when they went to the dash ****on starter in cars. 53 first year of the key start.
  7. Hnstray
    Hnstray
    from Quincy, IL
    I'm thinking '53 or '54 for p***enger cars........
    Ray
  8. junkyardjeff
    junkyardjeff
    If you are going with a newer motor and want the key start a mid 50s Olds ignition switch will go right in the dash and have start along with accessory positions,I used one from a 53 Olds in my 37 Chevy and had it rekeyed to my original 37 key. Since I was still running a 235 I rebuilt a foot stomp starter and installed it so now I do not use the start position on the switch but glad I am using the 53 switch since I can turn it to the accessory position to listen to the stereo since I do not think the original switch had it.
  9. squirrel
    Or use a 53-56 chevy car switch, or a 55-59 chevy truck V8 switch.
  10. Voh
    Voh
    I was thinking one of these. But sounds like it was still just a on/off.
  11. squirrel
    any of them thru 1952 will NOT have the start position.
