Technical Early Hemi #2 (354 Hemi build thread)
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Dec 29, 2023.
  1. 57 Fargo
    57 Fargo
    I’m stopping in Edmonton on the way through tomorrow to look at another set of heads and possibly pistons. Just because a guy can never have too many early Hemi parts…
    slayer, bchctybob, SS327 and 5 others like this.
  2. gimpyshotrods
    gimpyshotrods
    Epoxy first, then cut.
    That way anything deeper is good to go.
    Truckdoctor Andy and 57 Fargo like this.
  3. gimpyshotrods
    gimpyshotrods
    True.
    I have stacks.
  4. In_Benzin_Veritas
    In_Benzin_Veritas
    from Toronto
    Ah yes the joys of machining.
    57 Fargo likes this.
  5. hemiracer
    hemiracer
    Do you want to know where Fargo COE is in Fort Sask?
    51pontiac likes this.
  6. 57 Fargo
    57 Fargo
    No need today, it’s a quick trip, I will be in touch with you in the spring on the truck
  7. Beanscoot
    Beanscoot
    The truck intake and carbs isn't mine, I just copied the image from a post earlier in the thread.
  8. 57 Fargo
    57 Fargo
    Doh! I’m itching for one now!
  9. 57 Fargo
    57 Fargo
    Bought another set of 354 truck heads…why not?
  10. 57 Fargo
    57 Fargo
    Small update, got all the bearings, the cam bearings came from my local parts store overnight, $80 Canadian so approximately 0.44 US.:D Still waiting for cutters for the surfacer. Also have a set of ‘58 10:1 392 pistons coming. Cam and lifters go out Monday to be reground.
    Oh and my valve parts from Hot Heads made it to a depot and hour from me then UPS lost it….:(
    Truckdoctor Andy likes this.
  11. patsurf
    patsurf
  12. 57 Fargo
    57 Fargo
    Got the surfacer back up and running at work, got a set of stock 392 10:1 pistons in fantastic shape. Still no parts for the heads, not getting much help from UPS or Hot Heads. Hopefully soon….
  13. 57 Fargo
    57 Fargo
    So not much to update, still waiting for parts….
    Truckdoctor Andy and 427 sleeper like this.
  14. 57 Fargo
    57 Fargo
    Huge update!!! UPS actually managed to get the parts to me! Still no sign of the first shipment. Let the games begin. Once I have time that is….
  15. That's good news! So, waiting on the cutters?
  16. 57 Fargo
    57 Fargo
    Nope cutters are done, I have cut a sample head, now just waiting for time.
  17. Ok, you said you were waiting on first parcel, thought that was the reference.
  18. 57 Fargo
    57 Fargo
    Sorry that wasn’t clear, Hot Heads sent the parts and UPS lost them, so Hot Heads reshipped it.
    Truckdoctor Andy and Algoma56 like this.
  19. 57 Fargo
    57 Fargo
    Actually got some stuff done after work today,
    Swapped out valve guides on one head, did the valve seats. The exhaust were perfect as is, the intake I cut. IMG_5872.jpeg
    I use Prussian blue to see where it’s contacting.
    SS327, Truckdoctor Andy and AndersF like this.
  20. 57 Fargo
    57 Fargo
    Everything is numbered so the valves go back to their home, I will lap the valves before final ***embly, mostly because it will make me feel better.:)
    Ran the head through the surfacer. IMG_5877.jpeg This head had a pretty good “twist” to it. Took about 0.004” to straighten it out.
    Final product. Next is measure spring installed height and final clean and ***embly. Progress at least!:)
  21. 57 Fargo
    57 Fargo
    Spent some time at work today, got the second head finished, guides installed, touched up some intake valve seats and surfaced it.
  22. 57 Fargo
    57 Fargo
    I didn’t have keepers for the second head and I was too lazy to dig around at the college. I’ll take some tomorrow and ***emble the second one after work..
    427 sleeper and Truckdoctor Andy like this.
  23. 57 Fargo
    57 Fargo
    Found a home in my office for the complete head until I’m ready for it. IMG_5893.jpeg
    RodStRace, dwollam, AndersF and 3 others like this.
  24. 57 Fargo
    57 Fargo
    Now have a matching set. Next is the block
    fauj, MRW1994, AndersF and 4 others like this.
  25. 57 Fargo
    57 Fargo
    Got to working on the block today, my crank guy has the crank ready, I’ll pick it up Thursday.
    Block is in the hone, it was already 0.040” over, I am taking it to stock 392 bore size, I have a very nice set of 10:1 392 pistons for it.
    Sharpone, AndersF and 427 sleeper like this.
  26. 57 Fargo
    57 Fargo
    Forgot the picture….its rough honed to within 0.003”. Tomorrow finish hone.
    Sharpone, dwollam, SS327 and 4 others like this.
  27. 57 Fargo
    57 Fargo
    No picture because it would look exactly like the last picture but the block is now finish honed. Picking up the crank today then ***embly can begin.
    Sharpone, SS327, HemiDeuce and 4 others like this.
  28. 57 Fargo
    57 Fargo
    Measured all the rods today, everything looks great. Got the block sitting in the surfacer to shave some off the deck… IMG_6147.jpeg
    Sharpone and dwollam like this.
  29. 57 Fargo
    57 Fargo
    •354 block/crank with 6.625 stroke
    •392 pistons, casting number 1732540, dome volume 13cc
    •Using 100cc head (typical for 331 heads)
    •Using a 0.045" thick head gasket
    stock deck height = 8.75c/r
    0.010 cut = 8.92 c/r
    0.020 cut = 9.09 c/r
    0.030 cut = 9.28 c/r
    0.040 cut = 9.47 c/r
    0.050 cut = 9.68 c/r
    0.060 cut = 9.89 c/r
    Variables:
    •105 cc head will decrease c/r about ½ point which is what is generally what is found when using 354 heads on a p*** car block.
    •When using a truck block, you would be most likely using the 1954-331 heads.
    •Thinner head gasket will raise c/r slightly
    Using the 1958 392 piston, casting number 1827804, will increase c/r due to a slightly larger dome volume of approximately 20cc.
    Estimate is 0.7 point of c/r based on the 9.25 vs 10:1 factory numbers.
    Without actually putting the 58 parts in a block this is my best guess.
    The above is a copy and paste of an email conversation I’ve been having with Gary @73RR regarding decking the block to gain a little compression, I have ‘58 pistons so I’m going to take 0.030”-0.040” off to end up between 9.5:1 and 10:1 ish. I appreciate Gary taking the time to educate me!
    Sharpone, dwollam, bostonhemi and 2 others like this.
  30. George
    George
    While decking the block you night check to see if both decks are equal distance from the centerline of the crank, and if square front to rear & top to bottom.
    Sharpone likes this.
