Folks Of Interest Early Hemi 331 Pistons difference
Discussion in 'The Hokey Ass Message Board' started by Devils-Driver, Mar 2, 2016.
  1. Devils-Driver
    Devils-Driver
  2. TR Waters
    TR Waters
    from Vermont
    The 55 is a higher compression piston.
  3. Devils-Driver
    Devils-Driver
    Ok. Can I use also in the '54 engine without any problems?
  4. 37hotrod
    37hotrod
    Yes, the pistons are interchangeable. I used the '55 pistons in a '53 block with '54 heads when I built mine. It's all good.
  5. GREAZERZ
    GREAZERZ
    from Frisco, TX
    Do we need to use '54 heads to use '54 pistons?
  6. 37hotrod
    37hotrod
    No, but the intake and exhaust ports are different from '53 to '54. Headers and exhaust gaskets are much easier to find for '54 and later.
  7. 73RR
    73RR
    For not much more money you can buy custom-forged pistons and actually get some decent compression.
    Those cast prices are down-right scary....:confused:
    Hnstray likes this.
  8. Devils-Driver
    Devils-Driver
    Thanks for the great help and I have learn some new things.
  9. 270dodge
    270dodge
    from Ohio
    Listen to Gary- 73RR. I built my first Hemi in 1965 and since then have owned 26 of them. The compression increase will wake that engine up. I do have a question about the octane rating of the available gasoline in Germany.
    In the USA an octane rating of 91 is common and 10-1 compression will work just fine.
  10. Devils-Driver
    Devils-Driver
    Here in germany you can take many diffrent gasolines.
    From 85 octane to 102 octane.
    Cheap gasoline in germany
    E10 has 85 octane
    Normal gasoline 91 octane
    Super gasoline 95 octane
    Super plus gasoline 98 octane
    And then some special gasolines with 100 or 102 octane.
    For cl***ic cars i take 95 octane.
    Greetings Mario
  11. 270dodge
    270dodge
    from Ohio
    10-1 talk to 73RR. As we say here "I have no dog in this fight". In other words I have no personal interest or connection. I just know that he is knowledgeable and a stand up guy. You will like the effect of the big compression.
