Technical Early Hemi / Cragar / starter
Discussion in 'Traditional Hot Rods' started by 3w Hank, May 9, 2026.
  1. 3w Hank
    3w Hank
    I has a 392 early Hemi and my idea was a Lasalle transmission behind it.
    I located up a Cragar 4001 adapter and it goes to a old Ford, but then another adapter to go to Lasalle.
    ( if anyone has a Cragar sadapter for sale contact me - please )
    The flywheel I has is a aluminium Schefer 146 tooth.
    I don’t know what Chrysler used or tooth on bendix std.
    -Question is, what starter was to be used to this set-up ?
  2. 1946caddy
    1946caddy
    from washington
  3. 3w Hank
    3w Hank
    The whole ideas is go vintage here.
    I don't know if Cragar did make the final adapter to Lasalle but I know Offy did and others ( based from early Ford bolt pattern.
    But as I has a 32 Ford frame it is narrow and Cragar chanched side on starter as otherwise it would be a case with a steering box ( std location )
    -But question it was Cragars design to a std Chrysler starter ?
    This partnumber many did use on this design was #4000.
  4. 3w Hank
    3w Hank
    Who living person on the planet today can know what Cragar used for flywheel ( dia / tooth ) on this adapters and starter ( tooth on starter ) or the early Hemis. In this case a 392.
  5. hook00pad
    hook00pad
    Hi Hank, there was a fellow who had a build thread on here a few years ago of a '38 (or so) Dodge G***er for South East G***ers racing. He ran an early Hemi, maybe a 392. His name was Tony? Turner and the thread was "Dodge This" or something similar. You might find some details on his thread. Good luck!
    Al Hook
  6. 3w Hank
    3w Hank
    I did try search and name popped up but no threads here.
    But if I was building a retro racer and use a 392 I was having a SFI bellhousing and a modern racing transmision.
    I hardley think someone can be legal to use a cast Cragar adapter.
    The flyeheel I has and a Lasalle ( time bomb ) is a Very stupied way 2026, even to get a icecream...
    Maybe some has a old catalog, and small notes on that partnumber what tooth, starter they required.
    Mybe its long gone information today.
    Few are that crazy bought this stuff.
    HotHeads had no idea.
    hook00pad likes this.
  7. Eddie
    Eddie
    from Georgia
    I believe that the 146 tooth flywheel uses Chrysler 6 volt starter whereas a 172 tooth uses the Chrysler 12 volt starter. 73rr on here can tell you for sure.
  8. 19Eddy30
    19Eddy30
    from VA
    @3w Hank
    Do not know if this will help ,
    I did a Internet search for Cragar catalog there where several links & catalog's
    linking back to threads here to HAMB ,
    The ""Internet Searching"" seem to bring up more search results
  9. tubman
    tubman
    I had a '54 short bell in my race car with an Offenhauser two piece adapter to an early Ford pattern CAE in/out box. I had a starter on it for tuning purposes,. The stock starter ('54 New Yorker) worked with the stock flywheel and two different aftermarket aluminum flywheels I subsequently installed. I think if you stay with "run of the mill" parts, it should work. I never knew here could be a problem until I read this thread.:oops:
  10. 3w Hank
    3w Hank
    I guess no issues but I has no parts to check with so its not that easy.
    I has try to search Cragar 400/401 adapters but no real information ( on my questions )
    As the early Hemi has the same rear bolt pattern this adapter fits them all ’late’ 331/354/392 but there are 146/172 tooth ( no clue on starters )
    So was the 392 12 V ?
    I think I know the 392 used 172 tooth.
    I do think my flywheel ( 146 ) will not fit but I has no starters to check.
    A buddy here has a 331 and he used a modify a Chrysler SB 60’s bellhouse but did not use Chryslers plate bolt the starter on so he had to make a longer own bendix ( but he builded it -92 so no real details, but his was free thinking, I has the Cragar.
    Guys today like use GM auto trans can get a kit from several choices and use modern mini starters.
  11. 3w Hank
    3w Hank
    On my search ;
    One at Hamb was selling a Cragar 400/401 and it was a new Weber 172 tooth flywheel in the kit.
    Now sold, and I try reach him but so far no feed back.
    I know so far the 12 volt starter was used in the 392 and they had the 172 tooth.
    I guess this adapter it accepting that 172 tooth and that 12 volt starter, but even if the 146 tooth might fit with the 6 volt starter its not a option, so I will try find a 392 std flywheel and starter.
    I know the starter is very heavy and I like a aluminium flywheel, but then I see it that is the key here ( as I know think )
    If anyone has a Weber or Schefer flywheel at 172 tooth I'm intrested.
  12. 51 mercules
    51 mercules
    I don't think Cragar ever made the final adapter either. Offy did part #3640. As far as your other 2 Cragar adapters the 400 and 401 their identical to the offy adapters. At the GNRS I talked to guys at Offy about the 3640 adapter and they were taking names and phone numbers trying to get enough interest to do a run of their 3640 adapter.
    51504bat likes this.
  13. 1935ply
    1935ply
    from peyton,co
    The 172 tooth flywheel is the one you need. You can get a light weight power master starter. Hot Head Hemi's sells steel and aluminum flywheels.
    51 mercules likes this.
  14. 3w Hank
    3w Hank
    I got feedback from the seller of the 400/401 adapters and he said they worked with 172 tooth and a std starter.
    I suspected Cragar never made the 3'd adapter.
    I know of a Offy 3640 20 minutes from me and a Lasalle trans and 32 frame/34 cross perfect for my project 392.
    We has no deal yet but good to know Offy might recast them.
    Just one question.
    I could use a new Powermaster starter instead of the std ( big in a 32 frame ) but the ***an has one more cast 'look' than the chromed Powermaster.
    But this was AI, according to a new starter might fit a 146 tooth flywheel in std position.
    Mention auto but not if manual trans was the same.
    I has ask Powermaster ( no feedback yet )
    For early Chrysler 392 Hemi engines (1957–1958), high-torque gear reduction mini-starters are popular upgrades to solve heat soak issues and improve clearance with custom headers. Popular options include the Powermaster XS Torque (e.g., part #9530 for 146-tooth flywheels) or versatile 1.4kW mini-starters available.
    Key Considerations for 392 Hemi Starters:
    • Flywheel Tooth Count: Ensure the starter matches your flywheel/flexplate, commonly 172-tooth for automatic 392s or 146-tooth for others.
    • Mounting: Look for starters with adjustable mounting blocks to ensure proper clearance with headers and oil pans.
    • Power: 12-volt mini-starters offer high torque (approx. 200 ft.-lbs.) for high-compression engines.
    • Application: These starters often fit 1951-1956 Chrysler 331, 354, and 1957-58 392 Hemi engines
  15. 51 mercules
    51 mercules
    What pressure plate would be used? Since the 3'd adapter is using a ford throw out bearing, fork and shaft? Would it be a Borg and Beck Mercury PP or Chrysler PP because of the Ford throw out bearing?
  16. 3w Hank
    3w Hank
    You are correct the 3'd adapter is Ford fork.
    I'm not build a racer here just something fit on the flywheel.
    The Scheifer 146 tooth I has had a surface diameter at 11".
    If the Powermaster starter ( 146 ) fit that adapter and the 146 tooth flywheel I might use it, but so far it look like I need a 172 tooth flywheel.
    I'm investigate if the automatic had 172 tooth and maybe manual had 146 (?)
    -I might has some std partshere to look at tomorrow.
  17. 1935ply
    1935ply
    from peyton,co
    The 172 tooth flywheel is what you need to use with the adapter. I also use a hemi to older ford adapter and then old ford to muncie 4 speed. That way I can use my 34 pedals, you need to use a 10 1/2 " ford pressure plate and have your flywheel redrilled for it. The power master was not my first choice either, but I don't want the big stock starter. I am running headers and the starter doesn't show to much.
  18. 3w Hank
    3w Hank
    1935ply,
    Great.
    -Now I know what to do, get a Hot Heads aluminium flywheel 172 tooth and a 10.5" Ford pressuare plate and Powermaster 12 volt starter.
  19. 3w Hank
    3w Hank
    H-H had only the aluminium in the 172 tooth flywheel, but it was drilled for an 11" B&B.
    ( I shore would prefere a old forged aluminium Scheifer or a Weber ) but.....how can I found one ?
    If I has a Flathead Ford V8 or the early Ford adapter to ( Lasalle ) with the 32 Ford fork/T/O bearing would not a Ford 'Long' pressuare plate be what to be used ( early Hemi ) but they are at 10.1/2".
    Ideas on that from go B&B ?
