Projects Early Hemi powered A coupe
Discussion in 'Traditional Hot Rods' started by trevorsworth, Sep 1, 2026.
  1. trevorsworth
    trevorsworth
    The opportunity arose to rearrange some resources. I now have entirely too many projects in my pasture but none of you would say no to this so I don't wanna hear it :p The Fordor is going away and my other projects are taking a backseat until this is at least a roller.
    It came with a pretty solid spare 31 cowl I can rob whatever tin I need off of...
    I don't have a lot of time lately but I want to burn hard on this and get it on four wheels ASAP, and I have a sweet running early DeSoto hemi sitting on a stand that has the perfect character for what I have in mind.
    My plan is to pair the DeSoto with a Mopar A833 using a Hemi Hot Heads adapter through a fresh rebuilt 49 F1 rear end I've been hanging on to. I have a T5 sitting around, but I think I'll break it, even stock the hemi makes more torque than the T5 is rated for. (I also have a good 39 trans but I think that's not even worth considering for this.) I think I want an 833OD for this... so I'll have to start fishing around junkyards. I need pulleys for that engine if anyone has any laying around...
    Something's telling me to build a 32 ch***is for this. I have a cut up A and a cut up AA frame I could rob crossmembers from. But I also already have a complete A frame and I'm leaning towards full fenders, so I'm not sure if there's any real reason to build a 32 frame just to cover it up with fenders.
    As we move into the fall and winter months I'm hoping I'll have a lot more energy and time for my cars. It's been a brutal and busy summer of just fixing other people's ****... at least it pays the bills.
  2. Nailhead Jason
    Nailhead Jason
    30 years ago there was a guy in Nebraska where my grandparents and aunt and uncle lived that had a heavy chopped 30 31 sedan on a 32 frame with 32 fenders and running boards that looked killer. Im sure the rear fenders took all kinds of work to fit the body right but man it was a cool look.
  3. Just Gary
    Just Gary
    Sounds like a great plan.
    Hemi-powered A's are the coolest!:cool:
    AHotRod and trevorsworth like this.
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Couldn't be more excited for you, Trevor. As soon as I heard the Hemi and '32 rails plan, I immediately thought of this car. Looking back, there are some things on it that aren't my favorite, but the overall feel is bona fide hot rod. Carry on!
  5. trevorsworth
    trevorsworth
    Thanks Joey! I'm still waffling on the 32 frame. I've been doing some homework and came across this car:
    https://www.jalopyjournal.com/forum/threads/model-a-hemi-and-the-six-inch-chop.969142/
    There is some extreme fab wizardry at work on this one that I can't hope to match, but this answered some critical questions for me -- basically I think I can get the car the way I want it on an A frame.
    Right now I have two A frames, both underneath cars, or a guy has offered me some boxed 32 rails for $1000 which I could finish out with A crossmembers from the junk pile.
    Right now I think the best move is to break up my blown up T-bodied A and use the frame from it as the starting point for this car. I've had a nicely built Z'd T frame sitting around forever I can rebuild the T on down the road and the A frame under that car is really nice. The frame under the Fordor looked kinda tired. I'll give it a closer inspection tomorrow, but I think it's rusty and probably not completely straight from how the car is sitting, and I know the frame horns have been broken and roughly re welded.
  6. trevorsworth
    trevorsworth
    Moving ahead. The car is coming home with me today so we can start on the prep work and patches.
    I've settled on stealing the frame from my T RPU (I will rebuild it on a z'd T frame I have). This frame will get the Tardel step treatment, a 31 AA front crossmember (to correct the radiator height), and I'll have to fabricate a K member for the A833OD I'll be bolting to this DeSoto using the Hot Hemi Heads adapter.
    I want a nice dash treatment in this car and I've decided to lean into the DeSoto theme. So I went on a little shopping spree.
    This 57/58 Fireflite dash cluster came loaded with all the gauges, complete dash harness, interior lights, dimmer switch, blinker stalk, etc. I'll have to figure out a good dash panel to mold this into once I get it in hand but shoebox dashes look pretty versatile and available so I'm leaning that direction.
    I found this great switch panel insert for that dash - machine turned with a Fireflite badge that will match the Fireflite wire caps on my valve covers.
    And since there's an ignition switch in it I figured I'd finish it off with a DeSoto key. I should be able to get any locksmith to cut this blank to work.
    Millworks has the boxing plates and early hemi motor mounts, so that's coming up once I get the frame out.
    Deutscher, Thor1, 1952henry and 4 others like this.
  7. AHotRod
    AHotRod
    Model A Hot Rods RULE
    Deutscher and Just Gary like this.
  8. Tim
    Tim
    from KCMO
  9. trevorsworth
    trevorsworth
    Salvaged the fuel tank, windshield frame, cowl band, dash rail, and filler panel off this cowl. The tank is rusted out at the bottom, but I'm not sure if I'll be able to retain a cowl tank anyway, so I'll just prime it for now and use it for mockup.
    I may come back for the firewall later. Right now I think it's a boon that the firewall is out of the body, it will really help with positioning everything.
    Deutscher and Thor1 like this.
  10. trevorsworth
    trevorsworth
    The eagle has landed... should be able to start making headway on the shell this week.
    Deutscher, Thor1, warbird1 and 4 others like this.
  11. trevorsworth
    trevorsworth
    Set of front juice brakes to go with the rears. I forget what drums these fit but if I remember correctly I have spindles for these.
  12. trevorsworth
    trevorsworth
    Found a visor...
    Deutscher, Thor1, dwollam and 4 others like this.
  13. trevorsworth
    trevorsworth
    Starting on primer so I can stabilize the car and get an idea of what I'm in for. I figured if I can get one panel a day at work it'll be one color before I know it.
    Got more than one done today but it was hours and hours of sanding to get to this point. I decided to start with the bad side and I was really surprised just how straight and solid it is. A couple little wrinkles and the usual rot at the bottom but it's really really nice overall. A lot of guys would just about bolt it down and run it as is...
  14. gimpyshotrods
    gimpyshotrods
    When you are ready to start on yours, let me know.
    I have an extra Chrysler 354 over here collecting dust.
    Deutscher, Thor1, Just Gary and 3 others like this.
  15. trevorsworth
    trevorsworth
    This cluster feels great in the car. It's big but not dominant and looks awesome and it came so complete. I think this is worth giving up the cowl tank for, I have a B17 oxygen tank to use anyway. Been super busy at the shop so I haven't got to do much yet but everything is shaping up great.
    Deutscher, Thor1 and Tim like this.
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    This car ruled... but what makes it look so good is they added a couple inches do the whole body at the bottom you can see where loudpedal welded it all. I think they called it the anti-section.
    This looks like its going to be a cool build.
  17. trevorsworth
    trevorsworth
    How cool is that floating badge???? It's supposed to lay flat but the pins are long enough that I can make it stand off a bit. I think I can use some clear plastic beads to make spacers.
    The key blank unfortunately does not fit the ignition barrel. It's kind of hard to be sure but it looks like the lock cylinders physically interchange within the switches from 1935 to 1971 (or later?), and the actual key profile I have should work in any cylinder from 1935 to 1955, so I ordered a 54 Dodge cylinder. If the blank will fit in the keyway, and the cylinder will fit in the 57 key switch, I should be able to get this one cut to match the keys that came with the cylinder, and then have one cool key and two spares.
    Deutscher, Thor1, Tim and 1 other person like this.
  18. caprockfabshop
    caprockfabshop
    Key blank logo is more similar to a 1950-54 Desoto, they stopped using Hernando DeSoto starting in 1955 I believe.
    Deutscher and trevorsworth like this.
  19. trevorsworth
    trevorsworth
    Yep, I found out it's an aftermarket key by a company called Autogram. I found one still packaged on ebay which helpfully told me what year keyways it should fit. Lol
  20. trevorsworth
    trevorsworth
    Today's project involved killing yesterday's project. Here's the frame I'll be boxing and kicking up in the back for this car...
    Deutscher, Tim and Thor1 like this.
  21. 59sedandelivery
    59sedandelivery
    And heres this GUY, JOEY in CA to Help get ya started down the path...LOL Love it!!! I was just over on THE KEEPER COUPE post and gonna tell him how to wire a Heavy Guage Drop cord off the DRYER/Stove house plug to run his welder out in the barn.... LOL
  22. trevorsworth
    trevorsworth
    I worked myself into a corner with the keeper coupe lol. Where it's at, I can't do the fab I need to get the rear end located in it until I get power run out to the shop, and since it has no rear end in it, it's a pain in the *** to move without damaging Sid's 4 link which I'm trying to save. That's why I'm trying to get this car rolling at my actual work where I have electricity :D
  23. The37Kid
    The37Kid
    Great find and build to follow!
    Bob
    Deutscher likes this.
