Early Lincoln wheels and Ford hubcaps problem...need help
Discussion in 'The Hokey Ass Message Board' started by HotRodMicky, Jul 5, 2008.
  1. HotRodMicky
    HotRodMicky
    Hi,
    i just mounted 16x5 Lincoln wheels on the rear end of my '33.Now my '40 hubcaps wont fit
    anymore .they hit the axle before they slip on.....
    Had 16x4 Ford rims before with these caps.
    Are there any 40-48 Ford or Merc hubcaps that are "deeper" that my 40s???
    I don't want to cut or grind on my axles
    It's about 1/2 inch....
    Any Ideas?
    Michael
  2. cuznbrucie
    cuznbrucie
    I have Lincoln 16" x 5"s on my rear and I regularly trade off my '40 DeLuxe Caps with some '48 Mercs that are on now.........also have run '47-48 Ford caps..........there's lots that ought to fit.....
    Not sure what may be wrong with your rear axle........my rear is out of a '48 Merc.......
    CB
  3. HotRodMicky
    HotRodMicky
    The Merc caps seem to have a lot of "crown"
    The look good!
    I have been told they are Lincoln, but they have no "Slots" (they are solid), so
    maybe they are something different.
    They have clips to hold the hubcaps.
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    I had this problem on one side & not the other. A comparison of the two hubcaps showed that over the years, the retaining portion of the hubcap had been bent inward due to taking them off & pounding them back on. I carefully straightened them and they fit - it's snug, but they fit.
    These are '40 Standard caps with the V8 in them, BTW.
  5. cuznbrucie
    cuznbrucie
    I think your problem is that you do not have Lincoln wheels in 16 x 5......must be from something else?......the hub caps attach in the center on the four *inside nubs*....no clips on early Ford wheels........
    Check on those wheels.....mine have slots.......
    CB
  6. FoMoCoPower
    FoMoCoPower
    why not post a pic of the wheels???
  7. HotRodMicky
    HotRodMicky
    Here are some pics...
    What are they??
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    Dunno - but they're not early Lincoln.
    Truck maybe?
  9. Deuce Roadster
    Deuce Roadster
    If you look closely ... you can see the 4 little nubs ... inside the rims that holds the hubcap in place ... on the type hubcap you want to use.
  10. FoMoCoPower
    FoMoCoPower
    International truck maybe?
  11. LIMEY
    LIMEY
    Micheal i have 16x5 rims on my 39 & they took some hunting down as they were only fitted to 41-42 Lincoln Mercury, i'm not using caps but it looks like they would clear the axle also my rims have nubs & not spring clips to hold the cap on.
    Kev.
  12. Flat Ernie
    Flat Ernie
    Tech Editor
    As mentioned, I'm running same rims as Limey - got caps on it. They're snug against the castlenut, but they went on. one had a bent in lip & I had to straighten it to get it to go on, but they're on...
  13. 1953 Ford Pick up's also had 16 x 5 Rims, and can be indentified by a small hole drilled in the web near a lug nut hole.
    HemiDeuce.
  14. HotRodMicky
    HotRodMicky
    I have a bunch of 16x4 and 16x4,5 Ford rims like in the pic.
    I thought maybe lincolns are a bit different. They have no slots where the rim joins the center.
    So i guess i have to take off my front hubcaps , too.
    Are different style 16" lincoln wheels? Pics anybody?
  15. HotRodMicky
    HotRodMicky
    Are the '48 Merc hubcaps availible as repros?Who carries them?
  16. The big center hole tells me you may have Jeep wheels. Not 100% sure.
  17. cuznbrucie
    cuznbrucie
    Vaphead here on the HAMB can get the Merc Caps for you......he got mine........a really good and reliable guy to deal with....
    PM him or go to his web site: http://www.riley-auto.com/
    Brucie
  18. PASTDUEBILL
    PASTDUEBILL
    I have a similar problem. Bought some lincoln hubcaps that won't fit my forty wheels. They are 46 lincoln. They will almost snap in but I think lincoln wheels have retaining clips.
  19. HotRodMicky
    HotRodMicky
    do you still have the hubcaps????
  20. HotRodMicky
    HotRodMicky
    Sure i know Eric.
    Great guy!
    i'm just wondering if all the hubcaps are embossed the same measurement....
    Michael
