Early Mopar Hemi Questions
Discussion in 'The Hokey Ass Message Board' started by rockable, Apr 30, 2010.
  1. rockable
    rockable
    I'm thinking about engine options for my '41 Plymouth coupe. An early Hemi would be awesome, IMO. I was looking at a '55 Chrysler 331 Hemi. I did some poking around on the internet and found this link.
    http://www.crankshaftcoalition.com/w...specifications
    Is it true the Chrysler engine weighs 720 pounds? How come the DeSoto engines were lighter? What does a Mopar flathead 6 weigh? A 360?
    Thanks for your inputs.
    Rock
  2. HemiRambler
    HemiRambler
    chrysler motors are physically bigger than their "little" brothers!
  3. George
    George
  4. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    If you really wanna stand out, build a hot slant six. Bill
  5. 73RR
    73RR
    As you dig for info, you will find a variety of published weights, all due to what was still bolted together when it was on the scale.
    Generally, a 392 block = 195-200lbs, 331/354 = 180 +/-; empty head= 68lbs; crank = 78 lbs; intake = 43 lbs...the rest of the parts are similar to a sbm.
    The flat 6 is very heavy, check over at www.p15-d24.com for a number.
    Consider that the DeSoto is about 15% smaller (both physically and displacement) than the Chryslers, and the Dodge is about 15% smaller than the DeSoto. Weights follow a similar path.
  6. fuel23
    fuel23
    from illinios
    1955-331 engines are sought after in the "nitro" world because of the flow of the cylinder heads. 354 and 392 are easier to find parts for. If you can get a 331 cheap, take it and hold on to it. But dont break it.
  7. rockable
    rockable
    Sorry. That ain't going to happen.
  8. 390kid
    390kid
    try the spitfire six. still a six but more cubes and you wont have the steering and suspension issues of trying to shoe horn a v8. and the engine compartment will still finish up nice, i think you can just flip the core support around and pick up the 1 3/4 . i was lookin at going 345 desoto in my 51 and its a big motor for those slim frame rails and they have to sit real high
  9. farmer12
    farmer12
    Glad to hear you're definitely going for a V8, music to my ears!
  10. The biggest problem you're going to run into is the steering gear clearence. I'd look for a Dodge Hemi...
  11. R Pope
    R Pope
    Yep, the steering box is a *****. Rack and pinion will fix it, or a front clip. We did a Camaro clip on our '41 Chrysler, but now a Mopar 360 doesn't fit! I hate SBC's, so I got a slant 6 to try.
  12. George
    George
    Put a rear sump pan, oil pick up, dipstick & tube from a van or pick up on the 360, should go right in, same way a rear sump hemi will.
