Technical Early Oldsmobile flywheel info needed
Discussion in 'Traditional Hot Rods' started by panheadguy, Feb 7, 2023.
  1. panheadguy
    panheadguy
    from S.E. WI
    I'm going to be looking for a stick flywheel for a 324 Olds . What characteristics should I be looking for? Tooth count? Diameter?
    Thanks!
  2. IronTrap
    IronTrap
    303 and 324 interchange. Either one works just match the starter to the flywheel you choose. If using a starter changeover you want a 303 with the early starter that has the bolt holes symmetrical. Later 303 and 324 the holes are offset and the solenoid hits the oil pan when flipped. Or you can dent your oil pan in like most hot rodders did back in the day.
    I’m running an early 303 starter and flywheel on my 324 with an old hildebrandt starter changeover and remote filter plate.
    Hope that helps!
    Tim, '40 Coupe Fan, warbird1 and 2 others like this.
  3. vtwhead
    vtwhead
    What starter and lower housing do you have currently?
    Here are starter numbers for reference:
    bchctybob likes this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Tooth count is 145 from '49-'53, and 176 from '54-'56. As you can see on the above listing, a '53 flywheel is unique. Last year of 145 teeth and first year of 12 volt starter. Also, if you happen upon a standard shift flywheel from a six cylinder Oldsmobile, it can be used on the V8, but must have about a 1/4 inch thick spacer between it and the crankshaft.
    '40 Coupe Fan likes this.
  5. panheadguy
    panheadguy
    from S.E. WI
  6. panheadguy
    panheadguy
    from S.E. WI
    Thanks for the info. I'm a little bit more informed now! Ready to hit the swap meets!
  7. vtwhead
    vtwhead
    The lower housing that the starter bolts to should be reviewed as well. Here is the list from the shop manual
    Case in point, a '54 starter will not mate up with the early 558709 housing. 54 would be a 12 volt starter and the housing was for the smaller flywheel and 6 volt starter.
  8. BJR
    BJR
  9. panheadguy
    panheadguy
    from S.E. WI
    You are a wealth of information. My son (this is his project) lives in Cornwall VT. With your permission I'll have him get in touch with you. Thanks
    Paul likes this.
  10. vtwhead
    vtwhead
    We have spoken before. He has my number
  11. 57JoeFoMoPar
    57JoeFoMoPar
    What transmission are you planning on using?
  12. FritzJr
    FritzJr
    You can also use a flywheel from a 1940's Oldsmobile 6-cylinder on the early 303's.
  13. Crusty Chevy
    Crusty Chevy
    I'd like to hear more about this, more specifics please.
  14. desotot
    desotot
    One of my neighbors has an olds flywheel on his 331 caddy, I think he said the bellhousins bolt up but that cad and olds are on opposite sides.
  15. vtwhead
    vtwhead
    warbird1 and Crusty Chevy like this.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...or he could read my post in this thread.
    Crusty Chevy and vtwhead like this.
  17. panheadguy
    panheadguy
    from S.E. WI
    Early Ford flathead
  18. saltracer219
    saltracer219
    B.O.P. 1964 and up. The same as my 1968 Olds 442
