Technical early small block Chevy timing tab
Discussion in 'The Hokey Ass Message Board' started by SDS, Nov 16, 2023.
  1. SDS
    SDS
    My 327 has a 1966 block and balancer- it's the old 6 3/4-in balancer that is about half as thick as a modern balancer. The timing tab on the original engine was welded to the timing cover - as the timing cover was trashed, I replaced it.
    The one in the photo below, which is a stock GM unit, completely covers the timing mark on the balancer
    I can't find a bolt on timing tab that will work with that balancer type in. Does anybody know of one, part number?
  2. Bandit Billy
    Bandit Billy
    You could cut and weld that one to fit.
    1971BB427, swade41 and Johnny Gee like this.
  3. Bob Lowry
    Bob Lowry
  4. JD Miller
    JD Miller
  5. pprather
    pprather
    SDS likes this.
  6. DDDenny
    Keep in mind the bolt on timing tabs (in general 69/later) were originally paired with a damper that is keyed roughly eight degrees off the early damper which has an inline timing line and keyway.
  7. SDS
    SDS
    That's great, but my balancer is 6 3/4" and not as thick as an 8"
  8. SDS
    SDS
  9. SDS
    SDS
    ...and that's part of the problem.
    I'm going to use a piston stop and determine the actual timing mark.
    Johnny Gee and Bob Lowry like this.
  10. pprather
    pprather
  11. Drill a hole at 4 degrees (or wherever you set your timing) so you can see the timing mark. Could be a bit tricky shining the timing light through the hole, depends on how close it is to the edge of the balancer.
    tractorguy likes this.
  12. SDS
    SDS
  13. jimmy six
    jimmy six
    IMG_0250.jpeg I make a pointer from a piece of welding wire and point it at TDC and use timing tape on the balancer if it’s not a 360* marked one. I paint the end white. I also do it on ***embly when I determine TDC…not a SBC but you get the idea..
    SDS and 1971BB427 like this.
