Early tachometers - Teach and Win!
Discussion in 'The Hokey Ass Message Board' started by Ryan, Oct 2, 2006.
  1. alchemy
    alchemy
    Big A, I'd clean those gauges up before writing them off as "bad condition". They look pretty nice to me. Whatever you do, DO NOT have the faces rescreened! To me, and I would guess a lot of other SW collectors, the gauge is worth half if it's been rescreened.
    Here's some pics of my oldest 8000 mechanical tach, and a winged electric 8000 tach. The mechanical is not a Maring conversion but a true SW, and you can see it is not as artfully typeset as other SW gauges usually are. I take this to mean it was a quick response to seeing a market for high RPM tachs and filling it in a hurry. Can't read the date code on the back of this one.
    The electric is date coded to August 1955.
  2. 36C8
    36C8
    Agree 100%. I usually reface only my complete re-builders. Would not re-face yours, they're fine.
    Stewart Warner made a lot of one-offs. After having thousands go through my hands, I still run into odd-balls.
    I know they were making winged gauges at least in early 1949, per Tommy's post.
  3. Terry O
    Terry O
    Here's an early one on e-b** # 300034505473 you can check out....
      28.3 KB
  4.
  5. kroozn1
    kroozn1
    This is a bit OT.
    I have had this oddball in dash tach I can't find any info on.
    Under the RPM X 1000 is printed: Shift Indicator
    In the lower right is printed: Offy Products ****ord PA 1960
    In the lower left : World Rights Reserved.
    Anyone have any info on this one?
    Sorry about the bad pics.
    Carl
  6. 36C8
    36C8
      65.1 KB
  7. The red logo does look like a football.
  8. No worries, I feel the same way. From the front they will not change (maybe a bit cleaner), but I would like to run them. I just want to make them work, no look new. They were stored in a damp ba*****t for 50 years and they are not in great shape. Some are worse than others.
    36C8 was good enough to p*** along some info for me, so I think I'm headed in the right direction.
  9. Ryan
    Ryan
    ADMINISTRATOR
    Great stuff fellas...
    So what is the best option for a guy with an early flathead and no real desire to run a mechanical tach? I would love to see one of the big early tachs converted to a modern electrical job... Wire off the ground on the dizzy, etc...
  10. alchemy
    alchemy
    Why don't you want to run a mechanical? Is it cost?
    I know some of the drives for flatheads are bringing around a thousand on Ebay, but its gonna cost close to that to have your old electric converted to modern internals. The original mechanical head might cost a little more than an original winged electric.
    What kind of tach are you looking for? What kind of gauges does it have to match?
    For my next flathead build, I think I'll investigate a tach drive off the back of a generator, rather than spending big bucks for a crank drive. I bet my machinist could whip up something.
  11. 36C8
    36C8
  12. Ryan
    Ryan
    ADMINISTRATOR
    Yeah, it's mostly cost... The mechanical stuff IS the way to go, but man is it expensive... I'd like to try and tackle a electronic conversion myself...
  13. Lucky Burton
    Lucky Burton
    OK I had to log onto internet explorer to load a picture but here it is Ryan. Oh yeah the clearing the cache didn't do anything for my ****py Aol...oh well
    LOUIELOUIE likes this.
  14. Lucky Burton
    Lucky Burton
  15. 49ratfink
    49ratfink
    here's one I picked up at an old truck yard. the owner said it was from an old deisel truck. reverse rotation. very nice, back lit, mechanical ... I've been watching SW's since I picked up a "pressure" gauge with a crescent pointer and got over 200 bucks for it.
    anyone know of an automotive application for a reverse rotation tach??[​IMG]
  16. 49ratfink
    49ratfink
    ...heres the other side[​IMG]
  17. 49ratfink
    49ratfink
  18. alchemy
    alchemy
    That's the same kind of Police Special I have in the sedan I built (search Bud's B), but I've never had mine pegged!
  19. AV8-Rider
    AV8-Rider
    You'r lucky allright.
    These two are the nicest couple of old racing gauges you could own in my opinion.
    I looked at a pair on eBay a while back.......was a tought decission not to saccrifice A LOT to take them home.
  20. AV8-Rider
    AV8-Rider
    Here's my mech S&W tach and some others from the shelf.
    The tach housing is no deeper than a regular 32 speedo.
    Paul
  21. 36C8
    36C8
    Good stuff! An Auburn panel is my current project...
      21.2 KB
  22. AV8-Rider
    AV8-Rider
    Are cables for these old S&W tach the same? I'm thinking of the end/conection that goes into the tach.
    In other words: What to look for? Haven't got a cable yet. I also have to make some gismo for connecting it to the crank. I'm using stock 32 motormounts on my deuceframe and that leave out the pricy nice old bracket on eBay I guess. It's bolted to the 2 holes where the mounts go.
    Got any gauges for the Holy grail 36C8???
    Paul
  23. Aren't all the mechanical tachs designed for automotive use driven off the distributor?
    Making a crank driven cable too fast?
  24. 50shoe
    50shoe
    so its not 'merican but smiths was making tachs for british cars in the mid to early 50s. they had bad*** gold faces too....
  25. Gr8ballsofir
    Gr8ballsofir
    CLICK!
    I saw a Hildebrand distributor extension for an early Hemi, this weekend at a local swap meet. It had a horizontal hole in it with a drive gear inside. The guy wanted $50 for it and I had no idea what it was. Damn...:mad:
  26. Lucky Burton
    Lucky Burton
    Thanks. When I had the chance to get these gauges I didn't hesitate...Here is a picture of my dash and some of the other Stewart Warner gauges I don't have them all in there as I was still collecting them when I took the picture. All 2 5/8 and I have two more smaller matching gauges to drill into each side. The dash I custom made with engine turned panel and polished stainless border with rivets.. 8 gauges total.....Lucky
  27. 36C8
    36C8
    Just need a 60 amp gauge. I've got all the others and an 8k backmount tach.
  28. lakes modified
    lakes modified
    I run one of the distributor sandwich type in my flathead powered dry lakes modified. It was missing the dist. parts, so I sent it to a so. calif. shop and had electronic guts put inside while keeping the old crusty face and gl***. It ran $200 for the conversion, but works great and keeps the old patina. I see those type of tachs all the time at swap meets and ebay and they are usually missing the dist. parts to them. They can usually be bought at a reasionable cost.
  29. AV8-Rider
    AV8-Rider
    Lucky
    nice dash endeed.
    36C8
    Is that 8k backmount tach custom made into an old housing ?
    Gauges are fun. I owe my interest to my friend, klazurfer, who showed an Auburn panel and some gauges up under my nose some years ago to let me sniff.
    It stuck. :)
    Paul
  30. Ryan
    Ryan
    ADMINISTRATOR
    PMs sent to multiple folks that I owe decals too... great post fellas... I ****in' love old gauges...
    deucepickup32 likes this.
