Early tachometers - Teach and Win!
Discussion in 'The Hokey Ass Message Board' started by Ryan, Oct 2, 2006.
  1. Toddjg
    Toddjg
    from florida
    Isn't there an adapter that would allow you to run a speedo and tach at same time from same source?
  2. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    how about using an inline speedo calibrator to gear down a mech tach?
    Im talking about the ones used in big trucks to change the ratio from the ****** to the speedo. I have one sitting on the shelf that reverses the rotation of the cable. Very interesting bit. Wouldnt that work for the reverse sweep tachs?
  3. alchemy
    alchemy
    How would that work? Speedo shows the RPM (measured in a linear distance) of the driveline after the transmission changes the output speed. Tach shows the RPM before the transmission changes it. The two are only the same at a gear ratio of 1:1 (high gear), with a manual trans.
  4. Anyone hear of a Jet-Tach? It is a V8 8000 RPM sweep Tachometer with a green and red wire..it definitely looks 60's vintage.
      81.9 KB
  5. Also have these, told they both in perfect working order. Are these rare? value if working good? both are in good physical shape, no peeling or pitting, do they both need senders? I am ***uming yes?
    I appreciate any info.
    thanks
    811892 sending unit
  6. I just purchased a 1939 Chevy 1.5 ton truck that has a working SW cable driven tachometer... Any information regarding the model or year of manufacture would be great. I also would like to find out where I can send it out to have the face restored...
    Thank you.
    8flat likes this.
  7. Dragging up this old post. Just recently picked up this tach and can’t find any info on it. I have a mechanical SW in my pickup so thought I would use the older one but cable is different. I got really lucky on the drive @ $50 cdn from a flathead guru on Vancouver Island. 98C4A680-6C04-4BEC-B7B2-8414E864C7ED.jpeg 3E878909-642E-4AD2-A290-B8B904512BD7.jpeg 87B81E9C-AF38-4A4B-A718-F07C46A661E1.jpeg
  8. Ned Ludd
    Ned Ludd
    I wasn't aware of this thread when I was all over this stuff in January. I wasn't aware of the distributor-cap cable-drive adaptor. Has anyone got a pic of one?
    It seems like something which could be 3D-printed, maybe? That'd make a 3:1 version possible, for my converted speedometer idea.
  9. AccurateMike
    AccurateMike
    Cam drive
    Generator drive
    For Ford sidevalve. Generator also fits older Ford diesel tractors.
    Mike
