1952-59 Ford Eastwood's expander wheel?
Discussion in 'Off Topic Hot Rods & Customs' started by 52ragtop, Dec 19, 2015.
  1. 52ragtop
    52ragtop
    from Nebraska
    Anyone using one.. Lots of good reviews but I have a question of speed.. They say 2400 RPM or less, but most all buffers are running 3450.. Are you using one? What RPM? Pros or Cons.
  2. Texas57
    Texas57
    Harbor Freight has a cheap variable speed buffer. I've put many many hours on the one I have, the only problem being the same as all their electric stuff...the motor brushes wear out quickly. The buffer does come with an additional set of brushes.
    I've never used anyone's expander wheel.
  3. BLUDICE
    BLUDICE
  4. 52ragtop
    52ragtop
    from Nebraska
    This is a bench mounted double end buffing motor, not an L head style.. Can't find that one on HF
  5. Texas57
    Texas57
    sorry...misunderstood what you were looking for.
  6. 52ragtop
    52ragtop
    from Nebraska
    I'd like to find a bench buffer motor with variable speed.. Eastwood's wants $300+ for a 2 speed.. Not ready to go there yet.
  7. Rui
    Rui
  8. Rui
    Rui
    Sorry not a grinder? A sander?
  9. Mark T
    Mark T
  10. Rui
    Rui
    Cant tell Mark T, I'm not very into electronics/electrical stuff besides the basic stuff, but yeah, I guess so.
  11. 52ragtop
    52ragtop
    from Nebraska
    Well with Christmas rush it's been hard getting to Eastwood's Tech support, but finally did. Reason they are rated at 2400 RPM is the belts get very aggressive at higher speed. I already have a double shaft buffer and the way my small shop is set up, I don't want to add another.. I am looking at a speed controller, wondering if a simple light dimmer switch might do the trick.
  12. Texas57
    Texas57
    I'd be surprised if the amp rating was adequate. They usually tell you not to use those even on a ceiling fan!!
  13. koolmercuryman
    koolmercuryman
    from iowa
    why can't you use a dimmer switch
  14. 52ragtop
    52ragtop
    from Nebraska
    Yeah I am going to look up an old fried who is pretty good on this stuff and see what he can recommend.
  15. Texas57
    Texas57
    Thought I added this earlier, must have forget to hit the post ****on...again.
    How about a foot switch from a sewing machine? You might find one at a thrift shop really cheap.
  16. the-stig
    the-stig
    Harbor freight has this one, $20, I've used my neighbor's with my router, works pretty well.
  17. 52ragtop
    52ragtop
    from Nebraska
    Those work pretty good on brush type motors but not so well on shaded pole or other brushless motors. Lot of good reviews for light dimmers etc.
  18. danman55
    danman55
    How about the model train transformer/power packs? I think when I was a kid I used to have one for an HO scale railroad but I sure don't remember amp load...
  19. 52ragtop
    52ragtop
    from Nebraska
