Technical Easy circle cutter
Discussion in 'Traditional Hot Rods' started by FANTM58, Nov 22, 2013.
  1. FANTM58
    FANTM58
    OK so I needed to cut out a round plate , and did not want a pilot hole
    that you get from a hole saw. So I tried this , and it worked out pretty good !
    basicaly your still use a hole saw to make a guide in some wood
    then remove the pilot bit , and sandwitch the metal in between the wood
    clamp it and drill it out !!!
  2. That also works when you need to cut a hole bigger than the original holesaw hole. I also use it while woodworking. Many time salvaged doors will have a smaller than standard lockset hole. Pilot from the outside instead of the inside!
  3. blowby
    blowby
    from Nicasio Ca
    Good one, thanks!
  4. ydopen
    ydopen
    Good idea.
    John
  5. Mr48chev
    Thanks, that just solved a problem that I needed a fix for and all too easy too.
  6. Noland
    Noland
    Thanks for the tip!
  7. Russ B
    Russ B
    I used that general technique when I had to redrill all the gauge holes in my '29 ccpu for larger Wings instruments, a few years ago, and did not have to repaint the panel.
  8. oldsjoe
    oldsjoe
    Now that's outstanding information! Thanks for the tip!
  9. luke13
    luke13
    very very handy tip.
  10. Rich Wright
    Rich Wright
    Simple solution for a frustrating problem.
    Thanks.
  11. Engine man
    Engine man
    from Wisconsin
    I just use a hole saw without the guide drill in my drill press and clamp the metal down.
