Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. novatattoo
    novatattoo
    from Canton,OH
    Maybe it swings up to let the driver get in and out. Otherwise thats just crazy........
  2. thechoop
    thechoop
    If the Elephant Man was a vehicle, this would be it.
  3. dante81_98
    dante81_98
    with it body dropped that much, that is probably where it sits normally. Here are some more pictures I have of that truck.
  4. That Econoline looks broken to me.
  5. torchmann
    torchmann
    from Omaha, Ne
    Mine's not as old as Y'alls'ss but it's an econoline. It's a 1982 E350 with an Advanced out of SLC Utah 4x4 conversion. has just under 80k miles and spent many years in denver.
    I'm chopping up a 77 econoline E250 for the good 460 and think I might be able to build a hotrod cab out of the roof, cowl, doors, and rear corners. I'd have to fab the floor and firewall and lower cowl but I think it's do-able, what the hell it's free parts to experiment with I'd have s****ped the stuff anyway so I'm going to give it a shot.
    I'm chopping it up the rest of the way this weekend.
  6. Oh dear.
    I'd duck if I were you.
  7. wacko
    wacko
    from Canada
  8. SanDiegoJoe
    SanDiegoJoe
  9. torchmann
    torchmann
    from Omaha, Ne
    Yeah, kinda. I have a mental disorder...I think too much, sometimes the stuff gets past comittee and out of my head. who would want a rolling tissue box? Only a maniac could pull it off:D
  10. Can you say "BUMPSTEER"?
  11. mothradeath
    mothradeath
    huh? b-u-m-p-s-t-e-e-r. not hard. now tell me why your too smart and dont think this can be pulled off? have you tried to do this? please elaborate so that i dont make the same mistake you did.
  12. torchmann
    torchmann
    from Omaha, Ne
    That would require a full dissertation on complete suspension theory. it's all interrelated. change one thing, you change it all.
    Bumpsteer on a solid axle happens when the arched spring flexes to a flat position and the axle moves towards the shackle. flat springs like on a mid to late 70's chevy 4x4 have less bump steer than high arched springs.
    Also if your drag link isn't parallel to a line drawn from the spring hanger to the springs shackle end it will be swinging in a different angle as the suspension when it travels and will cause bumpsteer. Just changing the axle won't cause bumpsteer but if the angles are all wrong after you do it and drop the front or lift the rear it will.
  13. Hellfish
    Hellfish
    Not sure I'd trust them. Their kit is for 60-66 Econolines. Econolines didn't come out until '61, and '67 wasn't any different than '66. Their facts aren't straight, what about their measurements?
  14. Hellfish
    Hellfish
    I think I said this earlier in this post, but a friend of mine used a dropped tube axle on his '64. I think it was a shortened Model A axle. Anyway, it dropped the van down pretty low, but after spending days basically re-engineering everything from the shock mounts to spring perches and everything in between, he said it rode like utter ****, was hard to steer and lost its short turning radius. Furthermore, there was no way to lower the rear to match without major frame surgery. OTOH, he was able to add disk brakes to the drop axle's spindles.
    Likewise, I saw a guy at the Cinematic with a chopped and dropped Econo. It looked good low, but he said it was really scary to drive and rode terribly. He had to change wheels for driving, and then change them back when he was at a show just to have driveable wheels, then have wheels that looked good. He obvioulsy could've engineered that better, but that means I know 2 guys with 2 lowered Econos lowered 2 different ways and both said the vans were scary to drive and rode like ****.
    It seems to me that maybe the lowered ones are more show than go.
  15. That truck is sitting without a driver, and unloaded I ***ume.
    The center link/ tie rod is almost resting against the leaf spring. It might just rub most of the time under load, but imagine hitting a pothole or bump on a sweeping 50 MPH curve. Bad news.
    Not saying the truck can't be lowered, just pointing something about about the photo. It's great to have something that looks rad for around town, but not cool to drive something unsafe on the highway.
  16. You can buy a tie rod "Drop Kit" to space the tie rod upwards.
    That has it's own set of potential problems with pitman arm binding or clearance against the oil pan/frame.
  17. ford5t1
    ford5t1
    from usa
    <!-- / icon and ***le --><!-- message -->
    I Just slapped this one on the cl***ifieds.
    yeah emailed you twice about the econo but no respons
    see ya
  18. torchmann
    torchmann
    from Omaha, Ne
    anything wrong with the stock axle?
  19. erock805
    erock805
    Mas is the axle I used under my econoline. No problems. If you look on myrideisme site you can see more pics of it. Stronger than a garlic milk shake.
  20. erock805
    erock805
    Hellfish. You know three guys with dropped econos. Mine rides on air very well. It took a ton of work. The only scary part of my ride is the play in the steering box. But, I got a NOS one from egay to install along with a new colum. Last, I just purchased a 250 from a maverick, and am locating an aod for ultimate cruising speed. Oh one more thing, dare I say.....AC. Call me a puss, but I wanna role in comfort.
    I can honestly tell it rides better than it did in its stock form. But it is an air car. If you dont like an air ride, you wont like it. If I did it again, I would use an IFS suspension in the front.
    The engine is in great shape, but Im gunna do some headwork and maybe a cam while its out. I drive my eco all around phx as it sits, except in the summer...too fnn hot.
    They can be show and go, just takes a ton O work. And if you wanna go lower than me, your lookin at even more work.
    Perhaps I missed Hellfishes point though, an easy static drop will give you some problems depending how low you go. You gotta narrow the front axle to get turning radius. you will have big clearance issues between the frame and and axle, rebuild the steering arm, shifter rods and stuff.
  21. Hellfish
    Hellfish
    No, you didn't miss my point, but I think you put way more work into it than the others I've seen. Maybe the AirRide helps, too. Questions come up all the time about how to lower an Econo. Since you obviously did yours right, maybe you could do a tech post for everyone.
  22. mothradeath
    mothradeath
    im going to be honest with you. after he mentioned it and you wrote this i looked into as many threads as i could about the issue because its still throwing me off a bit. all primarily steering issues correct? theres a FANTASTIC article in the new rod and custom about adding a rack and pinion to a dropped axle instead of a gearbox that eliminates bumpsteer. seems unbelievable straight forward. problem solved or am i just still not understanding?
  23. dante81_98
    dante81_98
    The problem you will run into with a rack and pinon is that the steering wheel is in front of the unit, not behind it like in your average car or truck. So somehow your steering has to make a U-turn to go back into the rack while being reversed in the process so you are not turning the opposite direction of the steering wheel.
  24. Church
    Church
    from South Bay
    Hypothetically, I am trying a product called "steer clear" to reverse my steering. Small, no slop, fits in the limited available space, and I hope to hell it works.
    Hypothetically.
  25. dante81_98
    dante81_98
    I was going to keep my mouth shut on that. Figured I would wait to get the report from you if it works out or not. But since you spilled the beans, keep us posted.
    Later,
    Chad
  26. mothradeath
    mothradeath
    holy **** thats amazing and holy **** do i feel like an idiot for not realizing it was that in depth. sorry guys....im learnin.
  27. Hellfish
    Hellfish
    That's pretty neat, RoadApple! Keep us posted
  28. Chaz
    Chaz
    Or make your own reverser.
  29. torchmann
    torchmann
    from Omaha, Ne
    I'm not saying putting a drop axle in it is going to create bumpsteer, I'm just getting technical on how this type of suspension either can or wont be affected by bumpsteer so the guys can figure out their own geometry when installing a drop axle so they DONT get bumpsteer.
    P.S. steer clear looks like rabid good ingenuity. I like it. I like the rack with the mustang II front end but I saw a case where a guy mounted his steering rack right to the front tube axle I don't know if that
    s what your thinking???? mounting the rack to the frame on a tube axle should be okay within a limited degree of travel (as long as the tie rods are fairly paralell to the axle) but as those tie rods change angle while the suspension is going up and down there might be a factor of the toe measurement changing by the square of the suspension travel.
    I'm not saying thats a bad Idea... for example, my 77 f150 does not have the tie rod that goes from steering arm to steering arm. to keep the tie rod above the axle to protect it from off road damage they ran a main tie rod from the pitman arm to the p***enger steering arm but the drivers side steering arm connects to the main arm near the middle of it. it looks like this letter y on it's side.
    Off roaders change over to the 79 bronco style that has a conventional tie rod from steering arm to steering arm to tame the steering when lifting this setup but in stock configuration drives excellent unless you get it going up and down pretty seriously or if both tires have unequal traction when going over a bump.
    What I do think is a bad idea is mounting the steering rack directly to the beam or tube axle because there is no way to isolate the suspension forces from attacking the steering linkage from the rack to the driver. I think it's ratrod fail and would result in breakage of the steering shaft between the rack and the driver. The rack must be mounted to the ch***is placing all suspension forces on the tie rods so these steering shafts are subject to only rotational forces.
    I think a rack would be best with a mustangII but if your running a beam or tube axle and don't like your stock setup and HAVE to have something different I would install a Saginaw power steering gear box in a cross steer arrangement. it would be simple and leave you with no dangers or headaches. You'd have to consider how clockwise-counterclockwise rotation will affect the box and which way the arm needs to be installed on the box to chose the right box to do it.
    You can mount the Saginaw on the inside or outside of the frame (2 different mirror image boxes) and some units have all splines cut on the pitman arm shaft so you can reverse the clocking of the arm on the shaft so the pitman ball is either under or opposite the steering shaft on the box(this can reverse the action of the box).
    They are on ford vans and pickups , chevy trucks, camaros... alot of things with different arrangements and are bulletproof for something like your van.
  30. mothradeath
    mothradeath
    ouch! those steer clear steering boxes are 600 bones:eek:. super trick tho.
    road apple. how low are you looking to go with yours? looks like a big big project. keep us filled in please.
