Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. Hellfish
    Hellfish
    Dropping the tank is easy. But if yours is rough, replace it with a 17 or 20 gal 65-70 Mustang tank. You can get them new for about $100 and they fit with a minor adjustment. Basically, you need to move the filler from the top to the side, and add a vent. You'll probably need a new Mustang sending unit too, but all that shipped and you'll be out less than $150 for all brand new, worry-free stuff.
  2. Hellfish
    Hellfish
    '67 Chevy vans are clearly a "newer" style, so no. The Dodge A100 and Econolines look the same before and after 64 (at least up to 67 for the Econolines). I may be wrong about Chevy though. I'll look, but I think teh earlier Chevy van was a Corvair.
  3. RodStRace
    RodStRace
    Early chevy has a flat windshield and the headlights are centered on the body line.
    Later has a curved windshield and the headlights are down in the grille. [​IMG]
  4. Straight Axle Steve
    Straight Axle Steve
    Just heard from Chris (vintage-vans.com). The early van get together is on rain or shine at Bakers of ****ord, Michigan. Sunday June,27th. If you like stub nose vans this is the place to see them. Check out vintage vans or bakersof****ord.com for more info. Last year was a blast.
  5. KCsledz
    KCsledz
    the rear looks sharp! how ya going to do the front?
  6. KSNPVMT
    KSNPVMT
    from St George
    gotta build a jig cuz im gonna build a drop in the center of the axle to clear the oil pan & crank...gonna narrow it 2" as well. Prob gonna 2 link with a panhard but have not decided yet. The steering is gonna be the tricky part. Might end up with a couple jack shafts in it to square it back up to prevent bumpsteer... but still working that out on paper.
  7. ol'chevy
    ol'chevy
    It has an automatic, an electric fan. It runs regular temp when in traffic or adling, then heats up on highway. It has new water pump, etc., and a new radiator, though the radiator may not be up to snuff........
  8. need louvers ?
    need louvers ?
    I'm not a cooling expert, but living in Phoenix and driving nothing but vintage cars kinda gives you a leg up on such things! First things first - does it have a thermostat? And what set point is it? No thermostat has a tendency to move the water through to quickly to cool at high speeds. The other thought is one we see commonly around here with electric fans - at highway speeds with a very narrow enclosed engine bay, an electric fan with a large motor and mounting bracket can actually create a restriction in air flow. I have tried to use electric fans, but find down here with our extremes that they just don't hold up well, and the aftermarket stuff just isn't very efficient. Might try going to a clutch fan from a later ford product and see if that helps.
  9. ol'chevy
    ol'chevy
    He has a 180 t stat in it. He actually made a tunnel that looks like a trans. hump in front of the doghouse to get even more air in it. The radiator is moved foreward, the elec. fan is mounted on the back(engine side) so it shouldn't block airflow.
  10. rev106
    rev106
    I have a tripple core mustang rad in my 63 and it cools very well and I don't even have a fan shroud.
    Sounds like you've gone to the ends with the cooling, the problem must lie in the motor. You may just have to live with it then.
  11. Have you had the motor open lately????? its possible you have water jackets plugged........FYI on my A-100 I used elec.fan(pulling) and a airdamn to get fresh air to it worked great here in Tucson
  12. Slick Steve
    Slick Steve
    from Indy
    So, using 14x7 inch wheels, with the stock brakes, what backspacing would I need for steelies?? Would these wheels still work after I do the disc brake conversion? I want to buy new wheels, and am hoping I will only need one set....
  13. yamadafacka
    yamadafacka
    what do you fellas do about vapor lock??? mine wouldnt saty running over 50 mph, it would choke and die( missed billetproof cause of it). looked at the fuel filter and the fuel was just boiling away in there. a few of my friends suggested that i make a heat sheild. anyone have any other ideas?
  14. Hellfish
    Hellfish
    stock wheels won't work with disks, but some aftermarket ones will. Do some measurements
  15. Payaso
    Payaso
    Something I've done to my 'Heavy' and others...is to 'insulate' the fuel line with a larger diameter peice of fuel line? So if your running 3/8" fuel line...take a piece of 1/2", split down one side and hug it over the 3/8", and secure it with some small thin zip ties, where it might come into contact with high temp? In my case, heater hoses. One of my other buddies was having the same problem Saturday when he got to Billet...the fuel was boling away in the filter. I'll send you a pic text of my gig...Just an idea...cheap too!!
    In the winter I 'hug' the whole fuel line to insulate it from the cold (like the 8 degree mornings we had this past winter!).
    Hope that helps?
    MONDO
  16. econolineherb
    econolineherb
    I went ol skool . 4 wooden clip on cloth pins on the steel fuel line close to the carb . Had cloth pins on every car/van i ever drove . I'm in southwest Fl . Heat index today 105 .
  17. yamadafacka
    yamadafacka
    haha i shoulda just asked you in the first place haha thanks payaso
  18. Payaso
    Payaso
    You got it Brotha...Anytime...
  19. Slick Steve
    Slick Steve
    from Indy
    Look what followed me home today...
    Im offically in the club! I pick up my 66' Heavy Duty today
    45,**X miles, looks to be in great shape. I think the tires and wheels gotta go, but let me know what you think!
  20. novatattoo
    novatattoo
    from Canton,OH
    Steve, hey that looks great! I'm not a fan of the wheels. I say steel wheels or slots.
    Later, Bill
  21. econolineherb
    econolineherb
    Looks great . Have to put full discs or something to cover the wheels . Anybody sending there vin numbers to one of the two Econoline groups for the data base and to be decoaded ?
  22. Church
    Church
    from South Bay
    Looks great Steve. You are starting with something in MUCH better shape than mine was......but mine was free.
  23. RodStRace
    RodStRace
    Just saw this 'over there' and thought it looked like a great start!
  24. Hellfish
    Hellfish
    Very nice! What motor does it have?
  25. Tim G
    Tim G
    Yeah that looks super straight and pretty original, i agree on the wheels though, they gotta go!
  26. Van Dutch
    Van Dutch
    VAPOR LOCK :
    Is it a six or an eight? Sixes have that problem sometimes. You can leave the doghouse open a bit to improve air flow and keep it cool when you aren't driving it, but you may also be able to put a spacer under the carb to lift it just a little higher away from the heat. Vapor lock is a fairly common problem on plymouth and dodge slant sixes that can be fixed with a spacer, not sure about yours.
  27. Slick Steve
    Slick Steve
    from Indy
    It's got a 300/3 speed.
  28. Hellfish
    Hellfish
    A 300? Someone upgraded! Nice.
  29. Slick Steve
    Slick Steve
    from Indy
    The wheels DO have to go....what do you guys think about these in black, not red, with wide whites? I cant really picture the van with it. Thoughts?
  30. erock805
    erock805
