Technical Eddie Meyer head info
Discussion in 'Traditional Hot Rods' started by Chainsaw chipper, Jun 13, 2025.
  1. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    I recently looked at a pair of 21 stud Eddie Meyer heads that have numbers stamped on the top edge .Both heads have the same numbers c121 and 500.Can anyone tell me what they are in reference to? Thanks
  2. Wright & Sons
    Wright & Sons
    from Tucson, AZ
    I'm still very much a newb, but perhaps the 500 is referencing valve clearance? I know my Offenhauser heads are stamped "400" on the top edge, referring to their valve clearance. But 0.5" of valve clearance seems larger than "normal" and would likely result in a fairly low compression ratio.
  3. Wright & Sons
    Wright & Sons
    from Tucson, AZ
  4. tubman
    tubman
    I think those .400-.500 numbers refer to the nominal amount of lift allowed and have nothing to do with clearances.
    Fordors likes this.
  5. Wright & Sons
    Wright & Sons
    from Tucson, AZ
    Yeah, instead of "valve clearance" I suppose I should say "valve relief"
