Eddie's 31 A
Discussion in 'The Hokey Ass Message Board' started by Eddie's chop shop, Jan 4, 2007.
  1. Chopperman
    Chopperman
    you're a tool.
  2. Eddie's chop shop
    Eddie's chop shop
    Hey Rich hopes this helps. It was weird it looked fine on my computer at home but now that I am at work I had to scroll also.
    Thanks for the support guys, I enjoy this board, (both getting and giving ideas), it ****s when someone comes along and ****s in your cheerios you know?
  3. langy
    langy
    Hey Eddie nice job your doing, Havn't seen this build before but i will keep looking.
    Steve.
  4. Why are you raggin this guys ***? Do I really give a **** if he copied somebody elses build??? NO!!! He's doing a sensational job. Just about everything that can be done to a 30's vintage rod has been done before. Does that take away from the ingenuity and ability of someone to produce their own version of a build they admired. Absolutely not.
  5. brown n down
    brown n down
    WOW, great work so far!! dont know how i misse this thread, but im subscribing!
  6. flatheadpete
    flatheadpete
    from Burton, MI
    I was thinking the same thing. Really cool car, though. Get it done and do some burnouts!!
  7. Eddie's chop shop
    Eddie's chop shop
    Time for an update, been working on a bunch of **** that doesn't photo well. Here is a shot of the fuel cell batery, and radiator all mounted. Its getting really tight back there.
  8. Eddie's chop shop
    Eddie's chop shop
    After making the mount I had a good rack to finish pressure testing the tank and putting in the tank sealor. Not necessarily very pretty, but what the hell you can't see the thing.
  9. Eddie's chop shop
    Eddie's chop shop
    Here is a shot of the finished pedal ***embly. I really don't recomend this set up as it doesn't leave alot of room for your toes sticking up, But as long as your not 6' 4 with your legs sticking straight out its fairly comfortable.
  10. Eddie's chop shop
    Eddie's chop shop
    check that, not quite finished I still have to hook up the throttle
  11. Eddie's chop shop
    Eddie's chop shop
    On Saturday I had the car up all day and got the brake lines all in and hooked up to the master, as well as the clutch. Put in the hard lines for the collant system, just needs the rubber
  12. Eddie's chop shop
    Eddie's chop shop
    Put the tank, battery, and radiator in today. Its damn tight, this is the first time having all this in with the body on!! I had been waiting for a neck for the fuel cell, and my buddy came through for me on Fri.
  13. Eddie's chop shop
    Eddie's chop shop
    Getting close, I can feel it!! I am waiting on Steering arm, bearings for the collumn, need some new bolts for my hair pins, gotta finish plumbing, haven't even started wiring, get the window cut down, and a whole lot of other junk
  14. Eddie's chop shop
    Eddie's chop shop
    Oh and the harness's are in.
  15. Eddie's chop shop
    Eddie's chop shop
    Side note for everyone reading this. I appreciate all the compliments and encouragement. There are alot of things that I have rushed through that will need attention later to get them all pretty, but that will be for next winter when it comes apart for paint.
    Also for those of you who have commented on the frame and didn't read the whole thread. The concept is from littleman, I really liked his frame settup so he deserves all the credit.
  16. Chopperman
    Chopperman
    your in the zone man. Sooooooo close.
    Ride looks AWESOME. I love the built in seat look.
    Are you going to run a shell up front or leave it nekid ?
  17. dodgerodder
    dodgerodder
    I think you are doing a great job. And you are making a ton of progress really fast. And you are doing what lots of the critics should be doing-actually building something instead of criticizing those that are
  18. Eddie's chop shop
    Eddie's chop shop
    The seats really turned out sweet. I am going to do a hard leather pad with hand tooled pinstripping, They are actually very comfortable too I think I nailled the lean angle etc.
    I am going to leave the front open, although I may add a 5-8 gallon moon tank for the "dragster" look. Also my fuel cell is only 8.5-9 gallon, so the extra capacity for long hauls would be nice. Whats your latest on your fuel cell?
  19. Eddie's chop shop
    Eddie's chop shop
    Thanks Man,
  20. tjroadster
    tjroadster
    Eddie,
    First off nice work. I'm not working on it yet but I will be. As for now my car is wheels, tires, and engine, ****** and an idea. Oh wait, I won a steering wheel on ebay today. My idea is real similar to yours, except roadster(I'm 6'6").
    Second, I dig the vet, I saw in in a couple different stages at the wednesday night Red Robin thing. I drove the 51 merc that was bone stock.
    Either way, if you wouldn't mind I would love to come buy and take a look at this ride. I dig it, I'm new to all of this, and would like to just get ideas and input from you.
    Once again, nice work.
  21. Eddie's chop shop
    Eddie's chop shop
    Thanks. shoot me a pm your welcome to stop by anytime. I am usually in the garage most weekends (and too many evenings)
  22. Eddie's chop shop
    Eddie's chop shop
    So in a cl***ic example of shoot first ask questions later. I decided to do some research on cowl steering. It seemed very simple at first glance, now that I have read up, I think I may have made a boo-boo or two. My hairpins are too short and my draglink is not parrallel to the ground/hairpins. I can solve both of these fairly easily if need be. I am so close to driving it, I'll wait and see what happens. Easy to fix. Tie rod is in front of the axle. Not so easy to fix. Frame is too low to get it behind there without putting a bend in it. The bend would be slight, so maybe not a problem.
    Search function is your friend.
    I finally got all the steering together last night and it does turn very nice with minimal effort at the wheel. We'll see what happens.
  23. CHRIS 57
    CHRIS 57
    from Upstate NY
  24. Eddie's chop shop
    Eddie's chop shop
    How close is the steering arm to the tire? Can you heat and bend the arms outward, making the tierod longer? This will make your Ackerman issues better.[/quote]
    That's a possibility. I could fake it up and see how it would do. Good suggestion Thanks
  25. Chopperman
    Chopperman
    Updates ?
    I want to see some burnouts mang
  26. rat seeker
    rat seeker
    That thing is Awesome
  27. Eddie's chop shop
    Eddie's chop shop
    IT RUNS!
    I terrorized the neighborhood on Sunday. No lights no windshield oh well. Engine runs GREAT! wasn't sure what to expect. I still need to get shocks on it. It does have some bump steer, not sure if I will work on it or not, have to get a few more miles on it at speed.
  28. Eddie's chop shop
    Eddie's chop shop
    Seats are very comfortable even without paddding I figured the bumps would hurt my ***, but it rides nice. Pedals feel awesome. Steers nice and easy. I get a shudder when letting out hte clutch, not sure where that is coming from I am ***uming my four link settup?
  29. 2manybillz
    2manybillz
    Bump steer - I think your cowl steering is mounted too high for the angle of your radius rods.
  30. arkracing
    arkracing
    Is the cage removable? - I'd like to build something similar to that for my pickup. I like how it is bolted and not weled to the floor of the car. Do you have any pictures of the "halo" or top part of the cage and where it is tied into the back of the car?
    Looks great!
