Eddie's 31 A
Discussion in 'The Hokey Ass Message Board' started by Eddie's chop shop, Jan 4, 2007.
  1. Eddie's chop shop
    Eddie's chop shop
    Its removable at the moment, but only untill I paint the car. Once the inside is painted the cage will get fully welded at the joints making "stuck" inside the body, but the body and cage will still be able to unbolt from the ch***is. I'll have to post better pics of the top part.
  2. K13
    K13
    Great build thread. The car looks super cool! Love the stance.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Feels godd, huh? Congrats. Now drive the wheels off it.
  4. Harris
    Harris
    Great thread, Love the info on the buildup
  5. Damn, how've I missed this thread. Gotta' subscribe.
    -bill
  6. tjroadster
    tjroadster
    Now I definitely have to come check it out!
  7. Bondoboy
    Bondoboy
    absolutely bad***. You did some nice work and it has a great stance and style. well done sir!
  8. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Wanna race ? Ha Ha Ha ..................Its a great feeling to pull it out of the garage under its own power........are you going to Paso ?.......Littleman
  9. Eddie's chop shop
    Eddie's chop shop
    You bet, can I put the blower on first? Might make it more of a race! No I am not going to Paso.
    Thanks again for your support. A friend showed me your build right after I got my A. Your car is what got me into the hamb and obviously set the tone for my build. I didn't originally intend to put hte radiator in back like you did. But it just did't look right up front after yours.
    I have not seen yours since the chop. Is it getting tight in there yet with that motor set back?
  10. Chopperman
    Chopperman
  11. Eddie's chop shop
    Eddie's chop shop
    Not to much to update. Been driving it a little, it was leaking coolant @ the intake/head so when you got on it, it was misting the windshield. So I haven't driven it other than a couple trips to NAPA, and the hardware store.
    I already had the other intake, but didn't want to put it on till I knew the enine ran strong. Less variables. Last weekend I rebuilt all three carbs, yesterday I pulled the four barrel settup and tonight I will probably start putting on the tri-power.
    I need to put up some pics with all the lights and stuff working, looks kinda funny with the two lights up front and no radiator.
  12. Eddie's chop shop
    Eddie's chop shop
    Before
    After 5 1/2 months
  13. Eddie's chop shop
    Eddie's chop shop
  14. kwiksilver
    kwiksilver
    I like the bulkhead fitting for the coil. nice clean touch. Hows the temp in the car with the radiator?
  15. Eddie's chop shop
    Eddie's chop shop
    Hard to say on the temp, I am using the hold your hand on the side of the radiator technique at the moment. It seems okay, although I still need to put in my vent ducts that are going to be inside of the rear tires. I have yet to drive it much yet do to a water leak. But hopefully the new intake will get dialed in tonight or tomorrow and I can get some miles on this thing.
    The bulkhead fitting fit right in the original hole for the fuel pet ****. and I wanted to do something with the tear drop indention in the firewall.
  16. Evel
    Evel
    I think it needs a grille shell even tho theres nothing in it,,,it makes the car balanced. Littleman can pull it off because of his motor being so far back..
    You could run a super chopped 32 with a solid chrome insert and the lines will
    flow better...Just my 3cents.
    Looking cool tho..
  17. Eddie's chop shop
    Eddie's chop shop
    I've been kinda thinking that too. May look off, but I like confusing people too.
  18. kwiksilver
    kwiksilver
    Have you noticed any turning problems with the tierod in the front? tire scrubbing or hard to make a turn?
  19. Eddie's chop shop
    Eddie's chop shop
    No, I was worried about it. I don't have stops yet, so at full crank it feels a little tight. Under normal cruising its great.
  20. THE CHIEF
    THE CHIEF
    from MIAMI
    that stance looks killer
  21. Eddie's chop shop
    Eddie's chop shop
    I finally got around to cutting out the visor. I wanted to do something different. [​IMG]
  22. the duke
    the duke
    I have to agree with evel that a grill shell will make the car flow alot better from the front end to the cowl. And the visor is diffrent but not my thing. overall a very well done car though
  23. 34toddster
    34toddster
    from Missouri
    I may have missed it in the post, are you using an additional water pump? like an elec water puppy or something, with all the tubing front to rear for the Radiator, bet that thing hold 5 gallons of water, it really should run cool..Bad *** project kept the pic's coming:D
  24. Evel
    Evel
    I liked the Visor before. somtimes less is more..
    it looks like your plasma cutter had a fight with your Visor and lost...:D
    its your own personal touch and I respect you for that..all that matters in the end is burn outs!! :D
  25. Eddie's chop shop
    Eddie's chop shop
    NO additional pump, It runs nice and cool right now. We'll see what happens when the 100+ hits this summer.
  26. Eddie's chop shop
    Eddie's chop shop
    Exactly why I did it. Most on this board probably won't like it, oh well.
    Now that I have been driving it awhile, I am definitely not putting a grill in it. I just like how it trips people out. At a glance going down the road it doesn't look like it should run or be street legal!!
  27. Eddie's chop shop
    Eddie's chop shop
    The pattern is kinda becoming a trademark of mine. I usually incorporate it in one way or another to my projects. This is where it started, on a bike I built and didn't want a "loud" paint job, so I did 3D billet alluminum.[​IMG]
    The pattern is the same just resized and done in more of a tribal style to leave enough meat to hold the visor together.
  28. Chopperman
    Chopperman
    I love the VISOR.....
  29. grego31
    grego31
    from Sac, CA
    nice build, I just spent half the afternnon in the garage working on my 31 sedan and after reading this, I might go out for round two.
  30. Royalshifter
    Royalshifter
    Moderator
    Tribal visor is not my flavor but the rest of the car is *****in'. I also have to agree with Evel, it needs a shell.
