eDead 80 sound deadener????
Discussion in 'The Hokey Ass Message Board' started by gearheadbill, Mar 17, 2010.
  1. gearheadbill
    gearheadbill
  2. gearheadbill
    gearheadbill
  3. big creep
    big creep
    you know ive used under coat before, and it worked out fine. havent had a problem yet.
  4. I used it about a 2 years ago, did the floor of a 1970 Monte Carlo and I liked it seemed to work pretty good, but I then tried "FatMat" it was a little bit cheaper and looked a little nicer had a nice blue logo on the material..I've since used that on 2 cars and worked great and was very happy with it...if you look at it, it looks exactly like Dynomat...they have both FatMat and eDead on ebay for sale all the time for good prices
  5. Master of None
    Master of None
    Haven't used it but have used Dynamatt. Its spendy.... works good but so does going to a Menard's or a Home Depot and getting some water barrier for ba*****ts. Same thing no fancy foil.
  6. tomjac
    tomjac
    I'm going to try some duct insulation from Home Depot. It's 1/8 inch thick flexible foam with fairly heavy foil on one side. It is self-adhesive, but I think it will need a 'boost' of some spray-on adhesive.
    I was $16 bucks for 15 square ft.
    If you really want to go cheap, find some foam-backed pieces of carpet. I laid some of that temporarily and seems to work great.
