Edelbrock #1406 help?????
Discussion in 'The Hokey Ass Message Board' started by RED DEVIL #1878, Oct 17, 2012.
  1. :confused::confused::confused: MY CARB IS AN EDELBROCK #1406 WITH ELECTRIC CHOKE, I AM HAVING A HARD TIME KEEPING MY CAR TO STAY ON, AFTER A FEW MINUTES OF HAVING IT RUN AND WARM UP , IT ALMOST SEEMS LIKE A COUGHING SOUND COMING FROM THE CARB AND THEN IT TURNS OFF, I ADJUSTED THE MIXTURE SCREWS TO WHAT IT ASK FOR 1 AND HALF TURNS, I AM RUNNING 5 PSI ON THE FUEL, I THINK I HAVE THE VACUUM LINES ACCORDINGLY, ALL VACUUM PORTS ARE USED EXCEPT FOR ONE OF THE VACUUM LINES IN FRONT OF THE CARB,I HAVE THE DISTRIBUTOR HOOKED UP TO THE PORT ON P***ENGER SIDE AND THE DRIVER PORT PLUGGED, I RAN THE BRAKE BOOSTER TO THE BACK OF THE CARB AND THE FRONT PORT IS FOR THE PCV, I ALSO HAVE A TURBO 400 WITH KICKDOWN AND IT IS RAN TO THE INTAKE, ANY HELP ANYONE, I THINK ITS SOMETHING SIMPLE?????????? :confused::confused::confused:
  2. henryj1951
    henryj1951
    from USA
  3. hotroddon
    hotroddon
    Does it die when it is idling only? Or can you not even keep it running by pressing the gas pedal ?
  4. I have pressed on the gas pedal and it idles and dies, it warms up a little and then dies after the coughing sound from the carb......
  5. wallyringo
    wallyringo
    sounds to me like a vacuume probelm, i had the same thing happen, as my engine would warm up the vibration would make a old vacuume hose come lose. double check the lines are going to the correct ports. what engine is it?
  6. It is a chevy 283 with a th400 trans, edelbrock carb #1406 and hei distributor, timing is correct and plug wires also.....all hoses are new..........
  7. Ole don
    Ole don
    Is the hot idle set to slow? If it runs while the choke is partialy closed, its running on the fast idle cam. Kick it off and it quits, that's the first thing to look for. Then, is the carb and gasket covering all the open spaces on the manifold?
  8. Tin Can
    Tin Can
    Is this how your vac***e lines are hooked up to the carb?
      67.9 KB
  9. carb and gasket are covering and are set correctly on the intake, the car runs when the choke is partially open, the car starts right up but then warms up and shuts off with a loud coughing sound from the carb, my vacuum lines are hooked correctly with one question, my distributor vacuum is that supposed to be hooked up to the non emmisions controlled port correct?? do i need to plug up the other one????
  10. alpo
    alpo
    Yes the port that you don't use NEEDS TO BE PLUGGED. For that 283, I think you need full vacuum on it. Drivers side and plug the other.
  11. 1-1/2 turns out is a starting place. Its generally close enough to start the vehicle , but rarely exactly correct. Your car shouldn't be running "good" when its cold and on the choke. Running yes , good no. It should be running rich, with significantly restricted air, trying to get up to operating temp.
    Try backing the screws out 1/4 turn at a time until it idles off choke.
    Then you can start tuning the engine.
  12. hotroddon
    hotroddon
    YES it does need to be plugged - you have a vacuum leak!
  13. So looking at the carb from the front the p***enger side vacuum port needs to be plugged and my distributor vacuum hooked up to the drivers side, correct????? I guess looking for the leak will be fun..........
  14. hotroddon
    hotroddon
    The leak is that you don't have one of those two plugged. Use one, plug the other. It will run hooked to either one, but depending on your distributor curve and vac advance unit, one will run better for you
  15. By backing the screws out 1/4 at a time when tuning the engine , where do i start, hoses timing , etc.?????
  16. Vac advance unit???? Where is that????on the distributor???if so , how do i adjust or check that????
  17. oj
    oj
    Are you using that carb on the stock intake for a quadrajet? that has large holes for the secondaries? If yes, did you get the plate that seals off the secondaries and mates to the carb? It is a flat steel plate that edelbrock makes to adapt the squarebore edelbrock carb to the spreadbore intake.
    Edelbrock part# 2732
  18. The carb is an edlebrock 1406 and the intake is edelbrock performer rpm just a gasket , do i need a certain plate for this set-up???
  19. Jimv
    Jimv
    With the air cleaner off & the car idling look in side the primaries and see if you see gas kind of dripping inside there.A common problem with any carb is that alot of times if you turn them upside down the little "balls" fall out & **** things up.It happens alot with the one at the bottom of the accelerator pump tube.The ball is used to pull gas into the tube when the pump piston goes up & then seal the "inlet" hole when the piston goes down upon acceleration.
    If your leaking gas into the venturis at idle you could have the back ****erflies open a little.
    JimV
  20. hdman6465
    hdman6465
    Edelbrock says you don't need a plate with the 2101 intake, but you most certainly DO. A quick check with a vacuum gauge will confirm it.
  21. robyyo
    robyyo
    from Orange CA
    Are you familiar with the difference between square and spread bore carburetors and intake's? The Edelbrock 1406 is a square bore carburetor and if you have a spreadbore intake manifold designed for a quadrajet carb then it won't run correctly.
  22. I have the performer edelbrock intake for the carb , is this set-up correct?? Do i need an adapter plate for this set-up??? I think i need to get a vacuum gauge...............
  23. robyyo
    robyyo
    from Orange CA
  24. BOOB
    BOOB
    from Taylor, TX
    Edelbrock has a tuning guide on their site that you should study. It goes over every tuning aspect and gives numerous examples on jet/metering rod combos etc. It's not very hard once you understand how it works.
  25. nmpontiac
    nmpontiac
    from Taos, NM
    Performer RPM part # 7101 should take the 1406, 7104 is for the spreadbore (Quadrajet)
  26. birdman42
    birdman42
    If it is a Performer RPM you do not need an adaptor.If it is a Performer than you will need one.I would start by adjusting the hot idle screw before you adjust the air mixture.
  27. It is a performer rpm, and the hot idle screw is which one?????
  28. birdman42
    birdman42
    The one on the throttle linkage.turn it in about 1/2 turn at a time and bring the idle up.How long have you had this vehicle.
  29. hotroddon
    hotroddon
    never seen any "little balls" inside an Edelbrock carb
    The one on the drivers side of the carb near where the linkage hooks up.
  30. Rok55
    Rok55
    from Cheyenne
    Thumbs up with Jimv, recently had a similar issue with the rear carb (an Edelbrock 1404) on the dual setup on my Belair. Took a look and surenuff had fueling running in the primaries. Carb had been sitting a while and need to be freshened up and a new float valve. If the carb wasn't new when you mounted it, take it apart and check it thoroughly and clean it thoroughly.
