Edelbrock 6x2 for 390 fe
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Feb 21, 2011.
  1. FrozenMerc
    FrozenMerc
    Ah yes, The New Process 435. Beyond Bullet Proof, and the rock crawler guys love the 6.7:1 1st gear. Used in Dodge, GM, and Ford Trucks from 1962 to 1992. God Damn things even have a PTO on them. I ran one for years in my '51 F-1 behind the 351W, never broke, just couldn't stand not having OD.
    I will even give it away to some one if they want to come pick the damn heavy thing up and get it out of my garage.
  2. mtkawboy
    mtkawboy
    One 4 barrel about 600 cfm on a factory or Edelbrock intake will make a nicer driving combo as will a 3 speed Od trans out of a 58 to 64 big ford FE. I used one in a 57 ford for years with a 406 in it. 6-2s is just a good way to set fire to a nice car & cross rams never were worth a **** on FE's
  3. 56 ford custom
    56 ford custom
    from Socal
    Mtkawboy, i hear ya out on all that. But i always wanted a hot rod with a6x2.
    Well i found a ******. How about a 1964 four speed top loader,short rear shaft,25 spline. Needs a rebuild and its out of a 289. Would this be fine?
  4. mtkawboy
    mtkawboy
    It will if you dont power shift it or do any standing starts. A big block large input top loader would be better. You will quickly get tired of trying to keep 6-2s running right but its your car, do whatever you want.
  5. 56 ford custom
    56 ford custom
    from Socal
    Mtkawboy, i will keep looking for another trans. But.for now i will grab this one.
  6. flatout51
    flatout51
    That ****** will work fine! They didn't have the big input shaft 4 speeds till the 428 came out.
  7. 56 ford custom
    56 ford custom
    from Socal
    It is a 25 spline shaft. Should i convert it to a 28 spline?
  8. supervert
    supervert
    how bout a zf 5spd out of a 90's f250 or 350, they can be had for around 6-700 and will handle tq just fine. they come in 3 bell patterns sbf, 385, and diesel. and all the gears will be usable if you get a g***er version
  9. 56 ford custom
    56 ford custom
    from Socal
    Well see heres the thing. I dont think i need a 5 speed. Im building this 3 window for around town and for the track.
  10. YoungGunn
    YoungGunn
    from Camas, WA
    Im building a 27 coupe with a 390 also. Picked up a Offy dual quad for it cheap. As for the transmission, I would deffinitly go with the top loader! You can pick a close ratio rebuildable one for not to much and as far rebuilding them their pretty straight forward. They will hold up forever compared to a 39 trans. Good luck on the build!!
