I have a Edelbrock 1806 with a single-feed fuel line and banjo fitting. I need a couple of replacement washers for the banjo fitting and they don't seem to be available without buying the fitting. I don't want to take the one I have off to measure it, but I think it's about 3/8" ID. Can anyone tell me where I might pick up a couple, and what size?
i think it is bigger than 3/8" ID , and i also think they are available from Mr Gasket ...i could be wrong? if i was at work i'd check the catalog for you
The nut is 3/4" and the washer is very narrow from OD to ID, so I think you're right about it being bigger than 3/8". The tech rep at Summit suggested I try the hardware store for 3/8" so I never gave it a thought. I'll see if Mr. Gasket has an online catalog. Appreciate you.
would anything like these work? http://www.oreillyauto.com/site/c/search/Washers/N0248/C0142.oap?page=9&results=20&sortBy=1
They very well could..........not sure about fiber. The one I have now is nylon. Had thought about a crush-washer from my local hydraulic shop.
Check with NAPA. They have the copper washers for the hose-fittings on a disc brake caliper. I believe they have an illustrated catalog page that will give the dimensions.
If there's one in your area, might try an Allis Chalmers (AGCO) dealer. Certain Roosa-Master inj pumps used this style of washer on the banjo fittings; and IIRC, they're 3/8 i.d.
UPDATE I called the Edelbrock tech line and was told those washers are hard to find, but the tech said he'd send me a couple. If it happens that will be great customer service. Thanks for all the input.
ive got 2 edledbrock carbs on my ranchwagon and ive replaced those washers with some from oreillys. just like the ones in the pics pinkynoegg put up. been there for a few yrs. and ive had them off a few times .if you dont get yourss from the rep. ill look for the package they came in and see if its got a part# on it...
Most harbor freight junk is just that, but they do sell a washer ***ortment that work okay and are really cheap. Under $10.
Give Godman Hi-Performance a call, 901-382-7404, www.godmanhiperformance.com they might have the washers.
