Edelbrock carb guys, can you help me out?
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Sinister, Jun 12, 2024.
  1. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    I'm a Holley guy so I don't know much about these carbs.
    AVS2 650. Had a pretty good backfire through the carb and it won't rev without stumbling/missing pretty badly now. Verified it is the carb by changing it out and not having the stumble/miss.
    What happens inside these carbs when you get a backfire through them that would cause these issues? I use this AVS2 as my mileage carb, while I use a larger Holley HP for power, so I'd like to get it fixed so I can continue using it.
    Thanks!!
    Deuces likes this.
  2. mohr hp
    mohr hp
    from Georgia
    They're pretty tough and they don't have a Holley style power valve. I'd suspect something as simple as a blown gasket or something obvious.
    Deuces and SS327 like this.
  3. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Base gasket looked ok. Maybe the gasket between the carb top and base?
  4. rockable
    rockable
    First, make sure you don't have a vacuum leak in the form of base gasket or other connection. Then, check the accelerator pump. You can see the squirter with the air cleaner off. After that, check the rods to see if the pistons are moving freely. Honestly, there is little to go wrong. Also, verify that you distributor is advancing. These are the first things to check.
    dogwalkin likes this.
  5. chicken
    chicken
    from Kansas
    Also check the spring on the secondary air door. The backfire might have affected the operation of that door. The carb top to base gasket is good to check as well.
    Deuces likes this.
  6. foolthrottle
    foolthrottle
    floats?
    Deuces likes this.
  7. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    It's definitely in the carb, it's running like a swiss watch with the Holley on it. I'll take a look at the things mentioned here. Thanks!!
    Deuces likes this.
