Technical edelbrock heads
Discussion in 'Traditional Hot Rods' started by Jroot, Nov 24, 2013.
  1. Jroot
    Jroot
    from ...Ohio
    I have a very old pair of Flathead V8 Edelbrock heads. Someone told me not to use them because of unseen corrosion in the jackets?
  2. JEM
    JEM
    How do they LOOK?
    Worried about casting flaws? Are they worth the time to make a couple plates to block off the water-jacket ports on the deck and intake surfaces and screw in a schrader valve, put 30psi or so of air pressure on 'em and see if they hold pressure? ****uming you're taking them to a shop to have the seats, etc, cleaned up the head guy might be able to do that for you.
    If they don't leak and if the chambers and gasket surfaces aren't*******ed then IMO it comes down to how much it costs to make them usable.
  3. Jroot
    Jroot
    from ...Ohio
    Sorry, forgot to mention that they were Flathead v8 heads.
  4. JEM
    JEM
    Still comes down to the same basic consideration - what's the overall condition of the castings, will they hold pressure?
  5. onekoolkat1950
    onekoolkat1950
    have a bench test done on them.if they don't leak run em.put some radiator seal in the first time you run them.
  6. Jroot
    Jroot
    from ...Ohio
