Hot Rods Edelbrock inlet washer
Discussion in 'The Hokey Ass Message Board' started by scoop, Mar 6, 2025.
  1. scoop
    scoop
    I lost the washer what else could use that would be resistant to gas? It has to thin.
  2. 5window
    5window
    I don't know,like did you call Edelbrock?
  3. scoop
    scoop
    They don't offer them. Jegs has some but they want $17 to ship them.
  4. Rocket Scientist Chris
    Make your own using nitrile rubber. How big/thick is the washer? I probably have some in my project junk!
  5. swade41
    swade41
    from Buffalo,NY
    Check a hydraulic store, I bought thin aluminum washers that had a rubber impregnated ring on them to fit my fuel cell.
  6. Happydaze
    Happydaze
    I'm pretty certain it's just an aluminium washer. Aluminium or copper should be fine. Or, as already suggested, a bonded washer / Dowty seal would work too. All readily available and plentiful online.
    Chris
    Oneball likes this.
  7. What about a copper washer from your local hardware store?
    INVISIBLEKID, saltflats and Just Gary like this.
  8. ^^^^ x2 for a copper washer.
    Just Gary and Truckdoctor Andy like this.
  9. scoop
    scoop
    I'll look around for a copper washer. Thanks!
    Truckdoctor Andy likes this.
  10. 2devilles
    2devilles
    Napa/O'Reilly/Autozone etc usually have a good selection of copper washers, just take the fitting down with you and match it up :)
    Paul and Just Gary like this.
  11. squirrel
    https://www.ebay.com/itm/166658340338?
    select 5/8" ID, get 5 for a dollar plus two dollars postage. And wait a week.
    Or look in your junk bin for a 5/8" ID washer, or gasket, or just make one with a single ply cardboard box and a pair of scissors.
    saltflats and 5window like this.
  12. deathrowdave
    deathrowdave
    from NKy
    Harley store also banjo nut washer
  13. deathrowdave
    deathrowdave
    from NKy
    Couple drops of blue lock ***e no washer needed , just a thought
  14. 325w
    325w
    You might look at Auto Zone. Here they have Edlebrock inlet hose barb fittings and tube flare fittings with the washer.
  15. scoop
    scoop
    Found copper washers big enough, no leaks.
  16. bjinx
    bjinx
    Where did you get them?
  17. scoop
    scoop
    O'Reilly I had to hog them out a little bit.
  18. bjinx
    bjinx
