Technical Edelbrock intake identification
Discussion in 'The Hokey Ass Message Board' started by '51 Norm, Jun 30, 2025.
  1. '51 Norm
    '51 Norm
    from colorado
    Hi guys,
    I have an Edelbrock blower manifold that I was told is for a Pontiac. It doesn't fit any of the Pontiac heads that I have. It is close but no cigar.
    The casting number is B20 am I wrong to ***ume that the "B" stands for Buick? All of the actual Edelbrock Pontiac manifolds that I have seen start with a "P".
    So far the internet hasn't been helpful, does anyone have an old catalog that lists the actual part numbers?
    I'm hopeful that the HAMB gurus can help me out,
    Norm
    Deuces likes this.
  2. squirrel
    edit:
    found a picture of it...
    might be for older heads than you have.
    Deuces likes this.
  3. '51 Norm
    '51 Norm
    from colorado
    It is my understanding that Pontiac heads came in three different types, 55-60, 61-64 and 65-79.
    I don't currently have any of the 55-60 heads so I can't verify if the manifold fits on them.
    I do have a 63 421 that is ***embled, I guess that I will have to remove the intake to see if the blower manifold will fit.
    Thanks for the information.
  4. I believe the B is just for Blower. The B10 is SBC and the B15 is for a 392 Hemi
    squirrel likes this.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, it fits nothing newer than '64. Are there two different water ports on the gasket surface up front? Edelbrock did that on the single and dual quad intakes so that they would work on either the 1955-60 or the 1961-64 heads.
  6. '51 Norm
    '51 Norm
    from colorado
    No only one on each side that are threaded for a pipe fitting. I think that hoses going from them to a remote thermostat are needed to complete the cooling system.
    I really want to use this manifold but it is going to be an adventure.
  7. squirrel
    at least it has a full gasket surface on top, so you probably won't need to O ring it?
  8. wheeltramp brian
    wheeltramp brian
    You got a picture of the one you have now. I'd be interested in seeing it.
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Screenshot_20250701_134442_eBay.jpg I meant on the sealing surface, like on the left side of this picture
  10. bchctybob
    bchctybob
    Get a set of 55-60 gaskets and match them up. I think you’ll find that the bolt holes and intake ports are pretty close but the water holes may differ by quite a bit. You can probably work around the water hole issue. 61-64 heads have a lot of strange openings in the intake manifold surface but you might be able to make thin aluminum shim/gaskets to close them up if the manifold doesn’t cover them.
    Algoma56 likes this.
  11. '51 Norm
    '51 Norm
    from colorado
    There is only one set of coolant holes at the front of the manifold, one hole on each side and they have pipe threads in them.
    I have the later gaskets and I know that they are different, I'm planning to order some of the earlier gaskets and see if they line up before I go to the trouble of dismantling my 421.
    SS327 and squirrel like this.
  12. '51 Norm
    '51 Norm
    from colorado
    OK folks, pictures and stuff. pontiac intake gaskets.jpg Intake gasket pictures that I stole from the rock auto catalog.
    Front of the manifold showing the coolant connections and vents that have been added to the rear of the manifold
    bottom of the manifold
    1/2" pipe connection
  13. squirrel
    so it fits the early heads, not surprising. Now you know
    NoSurf likes this.
  14. wheeltramp brian
    wheeltramp brian
    If interested in selling I'd be interested in buying
  15. '51 Norm
    '51 Norm
    from colorado
