Technical edelbrock linkage issues
Discussion in 'The Hokey Ass Message Board' started by verde742, Mar 19, 2014.
  1. verde742
    verde742
    Anybody suggest someone in Phoenix area that will correct my Edelbrock linkage on my Ford engine. name? number? address?:confused::confused:
    thanks.:rolleyes:
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Need more info. Two fours, trips ? What is going on ?
    Don
  3. verde742
    verde742
    Single four barrel, Just bot vehicle, has Edelbrock intake, manifold, carb. Opens just a short stroke then engages, p***ing gear linkage almost immediately. I just want instant gratification. To old and don't want to learn, just want to get in and drive to Mayo Clinic.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yeah, I wondered why you weren't just going to attempt to adjust it yourself. That linkage isn't very difficult to dial in and it doesn't take a rocket surgeon to do it. But I see your point. Hope you find a shop out there to fix it for you.
    But if you DO decide to try it, a 4 barrel setup is the most basic one so you will get lots of help on here. Maybe post some pictures of what you have.
    Don
  5. aaggie
    aaggie
    Any mechanic should be able to adjust your linkage. Let's say it is a GM product with a 700R4 trans. The TV cable needs an adapter bracket for the Edelbrock carb, if the previous owner didn't install the bracket you will never get it to work correctly.
  6. verde742
    verde742
    Don, appreciate your response, another issue. I have not learned to post on here, even tho I have tried. At this point in life & I have relocated, or out lived my support system, and not looked for or stumbled onto new friends with knowledge of my interest. the H A M B, is close. Hope-ing to find drawing of proper linkage. Or a shop willing to offer services.
  7. verde742
    verde742
    Its not Chev, Its Ford.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Give me some more info,what Ford engine? what is it in? what transmission? Maybe you can set it up like mine? If you could post a picture showing the Carb and the linkage you have that would help.
  9. tommyd
    tommyd
    from South Indy
    There are more than a few Hambers in the Gilbert area. Try posting with "need help in the Gilbert area" or something like that. Might get you a faster response.
