Hot Rods Edelbrock Regular Generator?
Discussion in 'The Hokey Ass Message Board' started by Rusty Knutts, Jul 23, 2023.
  1. Rusty Knutts
    Rusty Knutts
    Wondering which fan mounted generator you guys running the early Edelbrock Regular intake were using? As you can see this one leaves no room for belt adjustment? Thanks fellas! 20230723_162734.jpg
  2. 427 sleeper
    427 sleeper
    Carb spacer's or a shorter belt, maybe both, are the solutions that come to mind... :cool:
    mad mikey and Tow Truck Tom like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There was a thread not long ago showing off set generator bracket’s that bolt off the head if I remember correctly? I just can’t find it.
    mad mikey likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. chevyfordman
    chevyfordman
    Maybe one of Bob Drakes carb spacers would be just right.
  6. j ripper
    j ripper
    from napa ca.
    To my knowledge this unit was designed to work with an up to 48 generator. Maybe I’m wrong? It’s hard to tell from your photo angle how much clearance there is top and bottom. What’s the story on the generator? The case looks long. A 2 brush (case only) should measure 6”.
    Big Al likes this.
  7. Rusty Knutts
    Rusty Knutts
    Yes sir, around six inches. 1940 - 48 generator? Maybe 1/4" to bottom of carb. 20230723_215920.jpg
  8. alchemy
    alchemy
    Have you mounted it on an engine yet? To make sure the pulley lines up?
    I have an early tall Weiand, and it required a spacer to make the pulley line up. And providing more clearance from the carb.
    Primered Forever and Blues4U like this.
  9. j ripper
    j ripper
    from napa ca.
    Bolt it up to your engine (with gasket) put a gasket under that carb base and play around with some belt lengths. Also, make sure that pulley is tight and has the proper clip.
    mad mikey and Blues4U like this.
  10. Rusty Knutts
    Rusty Knutts
    I'm thinking I'll have to force on the shortest possible belt and hope there's enough room to adjust the slack out before hitting the bottom of the carb? The pulley is threaded and screws on the end of the shaft. Not seeing any place for a clip?
  11. j ripper
    j ripper
    from napa ca.
    I’d go with Alchemy’s suggestion and see where the belt lineup is. Yes, there should be a groove for a special clip at the end of the armature.
  12. Rusty Knutts
    Rusty Knutts
  13. BJR
    BJR
    How about a cut and weld on the bracket you have now to offset it to the side for clearance? Or are you going to run a fan on the pulley?
  14. Rusty Knutts
    Rusty Knutts
    Yes, running fan on pulley.
  15. BJR
    BJR
    Then only option is carb spacers, or a different generator.
  16. alchemy
    alchemy
    Rusty have you tried the lineup yet?
  17. Rusty Knutts
    Rusty Knutts
    No, but I was able to contact a gentleman that is currently running the Edelbrock regular intake. It doesn't appear he had any type spacer and he never mentioned having any belt alignment issues? I've ran Offys and Thickstuns and haven't encountered any problems. May depend on the generator? That what I was trying to find out.
  18. alchemy
    alchemy
    My tall Weiand was supposedly produced in 1939, making it an early speed part. I have used a 40 generator front plate and a 48 front plate. Both required a spacer to line up the generator properly.
    I thought your type of Edelbrock was produced rather early too, so maybe it might need a similar spacer.
  19. 2muchstuff
    2muchstuff
    from Eastern KS
    Using a 3 brush generator converted to 12V and using a fun products regulator that has the appearance of the original cutout. It's tight but clears the 97 on the Edelbrock regular tall intake. This is in my 32 roadster and also using an original 32 fan. All clears and all belt pulleys line up.
    I believe the 2 brush generator is slightly longer.
    Big Al likes this.
  20. bushwacker 57
    bushwacker 57
    3 brush mounted is 5 \ 8 inch shorter than the two.
  21. quickchangeV8
    quickchangeV8
    My 1929 roadster 59A flathead Edelbrock Regular intake with Stromberg 48 carburetors and 1948 generator that was chrome plated and converted to 12 volts. Just enough room to mount the generator and the belt lines up perfectly with the water pumps with no spacers or shims. Have you tried to mount the intake in a car?
  22. Rusty Knutts
    Rusty Knutts
    Hey thanks fellas. Looks great! No have not tried to mount yet. Running 2 barrel on cast iron untill I get fresh build broke in. Appreciate the info!
