Technical Edelbrock Vacuum Leak
Discussion in 'The Hokey Ass Message Board' started by Country Joe, Sep 3, 2023.
  1. Country Joe
    Country Joe
    Hi
    Just sharing in case anyone is chasing a vacuum leak on an Edelbrock. My car was running a "little off". It idled in gear(automatic) at 600rpm. After it got good and hot, the idle climbed to 1000-1100 rpm.
    I looked at the usual. Hoses, connections and gasket surfaces. Couldn't see anything wrong.
    Then today, as I was looking at the engine for another reason, I noticed the front carb (oh yeah. I should mention the car has two carbs) Well the front carb has a little br*** plug in the area of the choke mounting holes. The rear carb didn't. Just a hole. I thought, No F'n way. Can't be that simple. I started the car and put my finger over it and yup...****ing like a Hoover. I never gave it a second thought. It just looked like another hole to mount the electric choke. So, I plugged it and it's all good. Anyone ever have that plug blow out before?
    Here is a picture of the hole. Screwdriver pointing at hole.
    Jalopy Joker likes this.
  2. Jalopy Joker
    Jalopy Joker
    good find - what model carb? - any idea what was mounted to side of carb using so many flat threaded bosses ? open one you found for a vacuum hose ******?
    Country Joe likes this.
  3. squirrel
    That's the vacuum source for the choke pull off. If the carb has a round choke coil housing with the pulloff piston inside it, then there would be a rubber washer sealing the p***age. If it has a divorced choke, then there is a ****** there, and a hose feeding the pulloff diaphragm. If the carb had a manual choke then there should not be a hole there.
  4. chargin03
    chargin03
    My Edelbrock has had that leak since new with automatic choke.
  5. squirrel
    oh...here's a picture of what Edelbrock thinks the carb looks like with a manual choke...notice the plug?
  6. chargin03
    chargin03
    I see the plug but mine with automatic choke has had a hole since new with the vacuum leak .I guess I will find a plug.
  7. Country Joe
    Country Joe
    A 600 Edel AVS
  8. Country Joe
    Country Joe
    Yes. Thank you for posting the picture. I wanted to take a picture of my front one to show the plug but, you saved me the h***le.
    However, this is where, once again, I am a victim of my own stupidity. I took off the electric choke several weeks ago and installed a cable to control it manually.
    I just went out and looked at the e-choke body I have on a shelf and sure enough, there is a little o-ring that mates up with that hole. Sometimes I think I should just buy a 2023 Honda and leave the Hot Rods to the real hot rodders...lol But, I love them too much
  9. deathrowdave
    deathrowdave
    from NKy
    Just about every hole needs a plug or it will leak something
  10. I dunno... in some cases there are bad consequences for plugging holes.
    427 sleeper, da34guy and Bob Lowry like this.
  11. squirrel
    ....only if you leak something.....
    (dang!)
    427 sleeper and '28phonebooth like this.
  12. Bandit Billy
    Bandit Billy
    Shame on you. Nothing can be that bad. :cool: Come in off the ledge and have a ****tail.
    427 sleeper, 2Blue2 and Country Joe like this.
  13. mohr hp
    mohr hp
    from Georgia
    Yeah dude, don't quit now! If this was was easy, everyone would do it!
    Country Joe and 427 sleeper like this.
