Hot Rods Edelbrock X1 6x2
Discussion in 'The Hokey Ass Message Board' started by Tobywan, Sep 24, 2016.
  1. Tobywan
    Tobywan
    Stogy and dana barlow like this.
  2. Tobywan
    Tobywan
    Holley 94's with ford script on outer four. I think it may have done by Vintage Speed down in Fl.
    Sent from my SPH-L720T using The H.A.M.B. mobile app
  3. dana barlow
    dana barlow
    from Miami Fla.
    Best guess;In working order as seen in photos,likely from $1000 to $ 2000 depending on demand an who needs it,if thats anyhelp.
    F&J likes this.
  4. mgtstumpy
    mgtstumpy
    As it stands $1.5K guestimate. Market would decide. As stated looks fairly good and complete. I bought an original X1 and went from there acquiring parts over time.
    A new repop manifold is $500; add an progressive linkage (Edelbrock or Stromberg), another $230 or $320. Eelco fuel log (Update) $50, air cleaners with filters, $300 ($50 each), Holley 94 cores $300 ($50 each), carburettor rebuild kits $150 ($25 each), oil filler tube and breather, $15. Original not repop parts sometimes command higher prices.
    Tobywan likes this.
  5. Tobywan
    Tobywan
    I know the I guy I got it from had lots o cash in it but it was to much cfm's so he removed it.
  6. Stogy
    Stogy
    Nice Centerpiece for the table oops I mean Hotrod. It is a looker (and doer) for sure and totally HAMB friendly...Yes as Stumpy said all that stuff is reproduced so add it up and yes original is obviously more desired and pricey. I am running an X1 and am very happy with the reliability of it. The one I have was painstakingly polished and sets it off nicely. It came with the car so it's value??? I would say worth every penny...;)
    Here is a couple of ads for reference. I think 97's may be more desired so perhaps considering you can adjust accordingly.
    http://www.jalopyjournal.com/forum/threads/sbc-edelbrock-x1-with-six-stromberg-97s-complete.984124/
    http://www.jalopyjournal.com/forum/...-edelbrock-x1-6x2-with-stromberg-97s.1021079/
    Max Gearhead likes this.
  7. AKGrouch
    AKGrouch
    they look smokin great......love my deuces even if it is only 3x2.
  8. X38
    X38
    Did he give it to you, or did you buy it?
    How much are you calling 'lots o cash'?
  9. mgtstumpy
    mgtstumpy
    No expert however I did some more research on Dr. Google. :D ****ster here and others know a lot more than me and spe******e in these.
    6 x 97's (Strombergs) equate to 930cfm, 6 x 94's (Holleys) equate to 1050cfm at WOT (Wide open throttle). Utilising only the centre 2 carbs and blocking off the outside 4 equates to 310cfm with 97's or 350cfm with 94's at WOT.
    A progressive linkage allows you to run only the centre 2 carbs until throttle is 65% open. With this setup, it only idles on the centre 2 carbs. The outer 4 carbs kick in like secondaries once 65% is reached. A straight linkage operates ALL carbs at the same time, no 65% until all kick in.
    The most common and/or biggest problem is over carbing an engine. Essentially an engine is a big pump, if you have to much going in you won't get it out as the engine will be running too rich. Most engines don't run 100% volumetric efficiency (VE) and run around the 80% mark. Most of us don't run the engine to 5,000 rpm with the most common range from idle to 3,500 rpm with the occasional squirt every now and again.
    Nailhead Jason and Stogy like this.
