Edlebrock 1605 Question
Discussion in 'The Hokey Ass Message Board' started by hoodprop, Sep 16, 2013.
  1. hoodprop
    hoodprop
    Yes I know another carb thread. Ok I decided to go with a Edlebrock 1605 600cfm carb for my mild 350. Any suggestion on set up.
    Motor is a chevy 350 with a duel plane intake edlebrock and mild edlebrock cam. Bored .60 over with 305 HO heads. I have a fuel pressure regulator I know to set this around 3 - 4 psi. Holley mechanical fuel pump. I know I will have to do a little a fine tuning. Looking fo suggestion on setting this carb up.
  2. i'm not familiar with an Edelbrock # 1605 carburetor.....is that a new model?
  3. HOTRODPRIMER
    HOTRODPRIMER
    New one me also,but 9 times out 10 the Edlebrocks work great right out of the box. HRP
  4. hoodprop
    hoodprop
    It is a 600 cfm manual choke carb.
  5. BobMcD
    BobMcD
    I think it's a 1405. I would run it right out of the box and see how it performs for you.
  6. rustang
    rustang
    1405... great carb right out of the box.... you will be happy with it...
  7. dirty old man
    dirty old man
    All I can add is before you install it, check both float level and drop, as QC seems a little loose on this and most times it's off.
    Easier to check and correct {if needed) now than after you install. If you bought new, the manual encloosed in the box is very good on this peocedure. If you got used or otherwise don't have the manual I think it can be downloaded from Edelbrock site.
  8. greybeard360
    greybeard360
    You very seldom have to do anything more than set idle speed right out of the box. Great carbs and I use them before a Holley for street applications.
  9. shadams
    shadams
    Have the same carb, same engine, same specs, and did nothing to it and have no regulator with mech fuel pump, runs like a champ...
  10. hoodprop
    hoodprop
    First of all sorry for the miss ***le typing to fast and no proff reading equals looking stupid. Got the carb on. WOW what difference. Woke up my motor. It feels a little boggy on the top end I am going to put a fuel regulator on tonight to see if that helps also going to adjust idle screws a little more and va***n tune it. Very Happy with it.
  11. Merlin
    Merlin
    from Inman, SC
    Like the others stated it should work fine out of the box although I would raise the fuel pressure closer to 5psi instead of 3 to 4.
  12. hoop98
    hoop98
    from Texas
    You may want to change the step-up springs first. Your carb came with the 5 inch spring.
    Take a look at this;
  13. sunbeam
    sunbeam
    If you did not get a manual down load one It will answer most questions I've had the best luck the 1406 tune they seem to run as well and get better milage.
