Technical Edlebrock problem
Discussion in 'The Hokey Ass Message Board' started by Bbneeley, Aug 18, 2024.
  1. Bbneeley
    Bbneeley
    c10 350. If the fuel pressure is to high will it make the carb die out under load? Any help I would greatly appreciate. Rebuilt the carb idle and revs just fine. Put in gear and wants to load up and die. Fuel pressure is a steady 8lbs. Any ideas?
  2. SEEKONK JIM
    SEEKONK JIM
    sounds more like timing advance
  3. MCjim
    MCjim
    from soCal
    Fuel pressure seems a bit high, but don't think that is causing your problem...
  4. sunbeam
    sunbeam
    Try weaker metering rod springs. When you put the trans in gear my first thought is the vacuum drops and the metering rod system opens. At least check vacuum with a gauge.
    ClayMart likes this.
  5. Bbneeley
    Bbneeley
    Which color springs you thinking
  6. wheeltramp brian
    wheeltramp brian
    Depends on how much vacuum you have at idle.
  7. Bbneeley
    Bbneeley
    I have the calibration kit but what strength are the colors. I can’t find info about them
  8. miker98038
    miker98038
  9. Budget36
    Budget36
    I think Edelbrock says 4-6 PSI. As it pertains to the carburetor, maybe FP is increasing over the 8 psi you have.
    Just a thought since the post was about the carburetor.
    Rodney Dangercar and rockable like this.
  10. brigrat
    brigrat
    from Wa.St.
    OK I will say it first, go Holley!
  11. rockable
    rockable
    Lower the fuel pressure to the aforementioned 4-6 psi first, and foremost. Excessive fuel pressure will raise the fuel level in the bowl. If it's built to stock specs it should run just fine on a SBC.
    If it doesn't run correctly, check the floats. Once you're positive you have those 2 things right, you can begin the troubleshooting process IF you still have a problem.....and don't go Holley.
  12. zman
    zman
    from Garner, NC
    Put a good pressure regulator with a gauge on there. Set it to 5.5 lbs.
    I like the Holley 12-881 for these.
  13. deathrowdave
    deathrowdave
    from NKy
    I have owned a few Edelbrock carbs , always rich running . Tuned as well as possible , tossed them went to the tried and true Holley or Qjet . Q Jet is a mans best friend lookin for a carb
  14. winr
    winr
    from Texas
    Aye .... fuel pressure too high....
    Ricky.
  15. Rodney Dangercar
    Rodney Dangercar
    If your fuel pressure is too high and you balance it out to idle, yet it dies in gear, fuel is pushing past the needle and seat and leaking into the carb. This causes you to open the throttle plates up to keep it running when you are setting it up. Putting it in gear reduces the idle and the fuel overwhelms the engine, causing it to die.
    As others have said, get the fuel pressure right and then go from there.
    mad mikey likes this.
