Technical Edsel 410 engine
Discussion in 'The Hokey Ass Message Board' started by gatz, Oct 29, 2024.
  1. gatz
    gatz
    Anyone have experience with rebuilding one of these?
    Nephew has the 410 engine out of his 58 Edsel Citation and is aware of the deck being at 10deg w the bore. This doesn't present a problem when using a ridge reamer as it registers in the bore; not the deck?
    He also said that there's an outward taper near the top of the bore.
    Was this to facilitate installing the piston/rings into the bore on the assembly line?
    Was a ring compressor used, or was that taper enough to compress the rings
    So, if a ring compressor were to be used when installing the piston/rings, would the ring compressor “bottom out” at that transition, and the piston/rings tapped down into the bore with an appropriate tool?
  2. Mr48chev
    All I can say is that it is part of the MEL engine family http://www.ford-mel-engine.com/viewtopic.php?t=13
    We had a 58 Merc colony park wagon with a 430 when I was growing up and that thing was a beast.
    By "taper" do you mean a chamfer at the top of the bores?
  3. miker98038
    miker98038
    markstr likes this.
  4. Boneyard51
    Boneyard51
    The MELs are a little tricky. To cut the ridge, like you said , you need a bore based reamer. As for putting the rings in , used the regular thin band squeezer , just turn the ratchet part to the lower side.
    It has been 59 years , since I built one!
    Bones
    jaracer likes this.
