Edsel 473 motor: an FE?
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, Jun 26, 2008.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    A friend scored a '58, I looked @ the motor and was wow'ed by its intake. Prev. owner told him it's an FE, would the valley pan-style intake fit a 390 from a '65 TBird?
  2. Squablow
    Squablow
    The '58 Edsel offered two engines, a 361 ci and a 410 ci. The 410 inch motor had valve covers that said E475, denoting the torque rating.
    Assuming your buddy has a 410 cube E475, that is a M-E-L motor and a 390 intake will not interchange.
  3. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    And also the heaviest motor, or mass of solid anything, on Earth...ever.
  4. Crusty Nut
    Crusty Nut
    TIM, your back from the dead! I don't know the answer to the question, but I'm happy to see you here.
  5. Edsel engines.
    410 CI, a MEL engine, E-475 stamped in the VC's
    361 CI, an FE engine, #-400 stamped into the VC's
    292 CI, a Y-block engine. No markings on the VC's
    Then there was a six cylinder exactly like the Fords of the day
    The E-475 (410 CI) is a MEL engine just like the Mercury 383 and the Lincoln/T-Bird 430.
    The E-400 (361 CI) is an FE engine just like all Ford FE's (332 through 428)
    The Y-block 292 is a standard Ford 292
  6. Speed parts for the MEL is scarce. I have some if you are interested.
  7. modelAedsel
    modelAedsel
    from rocklin
    Beep what parts do you have?
  8. Actaully MEL's weigh about 680, that is similar to a Big Block Chevy, 50 lbs less than a 331 Hemi, 40 lbs less than a 429/460 and 5300 lbs less than a Lycoming radial 36
